Accent 2004 won't start - Hyundai Forums : Hyundai Forum
post #1 of 5 (permalink) Old 10-13-2011, 10:05 PM Thread Starter
Drives Accent 2004 gs
yanzx is on a distinguished road
My hyundai accent 2004 standart doesn't start. The engine crank, but there's no fire. I change the camshaft and crankshaft sensor. Also change my timing belt, my alternator, my starter, my control box and my computer. But if I pull the car with my pickup, it runs. While the engine is running, the computer doesn't give me any diagnostic code. Someone have any idea?
I also check my fuse, relay,... Even jump start the starter to check if it was the switch.
yanzx is offline
post #2 of 5 (permalink) Old 10-13-2011, 10:56 PM
santa06's Avatar
Quoted: 124 Post(s)
Wow that's a strange one.
When its cranking over is it turning fast enough ; try boosting it when starting to make sure battery amperage is there.
It starts immediately with a tow , or you only tried it once ? With window is down can you hear fuel pump pressurize for 3-4 seconds before starting. Were the sensors changed dealer parts or aftermarket. Control box ? means your ECM or main computer ?
In a dark garage if possible remove one plug wire, put on a good spark plug and lay it against metal under hood. Hold with insulated pliers or heavy glove if brave. You should see a bright blue spark , not yellow or orange. Weak coil if spark isn't blue.
Lastly what is the engine compression , even cold numbers are useful. Weak compression makes for bad starting, especially in cold weather when clearance increases.
santa06 is offline
post #3 of 5 (permalink) Old 10-13-2011, 10:58 PM
jsinton's Avatar
Quoted: 69 Post(s)
Weird, unexplainable electrical problems in a Hyundai? You live in Canada?
I'll give you 5 to 1 odds you have a bad ground, like a negative battery cable bolted to the body. If it was my car, I'd completely disassemble the battery cable connections, clean them real good, and reinstall with dielectric grease. Happens a lot to Hyundai, methinks.
jsinton is offline
post #4 of 5 (permalink) Old 12-29-2011, 11:19 AM
2005 Nissan Titan and 2004 Hyundai Accent
fsumitch is an unknown quantity at this point
Im having the same problem with my car. It cranks but wont start. I have an 04 accent. checked the timing belt, have new plugs and wires, changed the fuel pump as I thought at first it was the fuel pump but obviously it wasnt. Im gonna try cleaning the ground connections and see if that works. Im stumped!!!!
fsumitch is offline
post #5 of 5 (permalink) Old 12-29-2011, 02:34 PM
Cleaned all the ground connections and no luck!
fsumitch is offline
