P0501 Speed Sensor. - Hyundai Forums : Hyundai Forum
post #1 of 10 (permalink) Old 03-28-2010, 07:45 PM Thread Starter
RetsaM's Avatar
RetsaM
Send a message via MSN to RetsaM
Hello,
The MIL light up and I got the P0501 Code. (Speed Sensor)
I use a ScangagueII and the Speed is 0 KM/H at any speed. (was working before)
But the in dash Speed meter work no problem.
I look on the HMAservice web page and did not found were is located the Speed Sensor.
Somebody know?
I do not know if it is related but I change my tire for my summer tire before the MIL light up...
Thank you,
Jonathan Lévesque
RetsaM is offline
post #2 of 10 (permalink) Old 03-28-2010, 09:32 PM
rsquared's Avatar
rsquared
It's in the transaxle. This might also help http://www.obd-codes.com/p0501
There's never enough time to do it right, but there's always enough time to do it over.
rsquared is offline
post #3 of 10 (permalink) Old 03-28-2010, 09:44 PM Thread Starter
RetsaM's Avatar
RetsaM
The cable that go from the dash speed meter, yes, go to the transaxle and that one is working good!
But the speed I got from the computer when I drive is 0 KM/H.
I reed somewhere the 1.6L as the mecanic VSS for the dash speed meter
and a digital VSS for the computer... but where it is?
JL
RetsaM is offline
post #4 of 10 (permalink) Old 03-28-2010, 09:57 PM
rsquared's Avatar
rsquared
Look under the air filter box. go to hmaservice and search vss.
rsquared is offline
post #5 of 10 (permalink) Old 03-30-2010, 08:27 PM Thread Starter
RetsaM's Avatar
RetsaM
I look under it and I found something but it don't look like a speed sensor... it only have 2 wire instead of 3.
In the HMAservice site it show it could be at 3 different place... one on the transmission, on the speed sensor (reed switch) or at the front right wheel (ABS I supposed)
BTW I don't have ABS and it is a manual transmission...
Somebody got that problem ?
Thank you,
Jonathan Lévesque
RetsaM is offline
post #6 of 10 (permalink) Old 03-30-2010, 09:29 PM
rsquared's Avatar
rsquared
Sorry, I don't know why but I was thinking you had an automatic. Check TSB 00-36-011
rsquared is offline
post #7 of 10 (permalink) Old 04-04-2010, 08:56 AM Thread Starter
RetsaM's Avatar
RetsaM
I finally get some time to work at it Yesterday.
It was some rush and oxydation on the Reed contact switch behinde the cluster guage.
It is fix not and I have speed reading on the ScanguageII
The car is acting much more smoothly also.
Thanks for your help,
Jonathan Lévesque
RetsaM is offline
post #8 of 10 (permalink) Old 04-04-2010, 01:44 PM
jsinton's Avatar
Quoted: 69 Post(s)
Exactly, the VSS is different from the ABS wheel sensors on this car. It's just like he says: On the back of the instrument cluster. The pic above is a reverse lamp switch.
jsinton is offline
post #9 of 10 (permalink) Old 04-04-2010, 11:06 PM Thread Starter
RetsaM's Avatar
RetsaM
Thanks for the info I did not get any idear what the heck was that connector...
Humm...
I should connect a switch on that wire
so if somebody is fallow me in my but, I can turn on the reverse light...
RetsaM is offline
post #10 of 10 (permalink) Old 02-16-2016, 09:18 PM
2008 Hyundai Sonata V6 GLS
Stan1705 is an unknown quantity at this point
Got a car from the auction. It was sitting for a while before being sold. All of a sudden i start getting these codes P0501, U0001 & P0722(on this code changed sensor 4 times).
Could it be an ECU malfunction or it just needs to be reprogrammed?
Also if anyone knows if this might be the wire problem?
Stan1705 is offline
