Psf-3 Power Steering Fluid - Hyundai Forums : Hyundai Forum
post #1 of 11 (permalink) Old 02-09-2010, 12:17 AM Thread Starter
nick944's Avatar
'08 Elantra GLS '01 Accent GL (RIP)
nick944
PSF3 is what the manual calls for on power steering fluid for this Accent, though I can't find it! The dealer service department tells me they have never had PSF-3 or heard of it even after showing them my manual. They only stock PSF-4 and recommended it instead. From what I've seen PSF-4 and 3 are not compatible, 3 is clear while 4 is green. Some people say it's transmission fluid rebranded as power steering but SP-III is red. I know my mechanic got it when I had the engine swapped in December but I haven't been able to ask him yet where he got it, any idea where to get it?
nick944 is offline
post #2 of 11 (permalink) Old 02-09-2010, 12:40 AM
hyunnychub's Avatar
2011 Sonata GL, Pony
Quoted: 3 Post(s)
hyunnychub
i topped up with Bardhal Synthetic power steering fluid. Compatible with all power steering fluids, engineered for asian and european vehicles.
http://www.canadiantire.ca/AST/browse/4/Au...ing%2BFluid.jsp
hyunnychub is offline
post #3 of 11 (permalink) Old 02-09-2010, 01:01 AM Thread Starter
nick944's Avatar
nick944
I have seen a lot of threads with suggestions on replacement fluids for PSF-3 but I really want to get the original fluid if possible because I plan on running this car another 100,000-200,000 miles with minimal maintenance.
nick944 is offline
post #4 of 11 (permalink) Old 02-09-2010, 02:03 AM
jsinton's Avatar
Quoted: 69 Post(s)
It's just standard power steering fluid. You buy it at Walmart or any other place. It could be clear or red. The owners manual also says it's Dexron II ATF. Find another dealer, they obviously don't know what they're doing.
jsinton is offline
post #5 of 11 (permalink) Old 02-09-2010, 06:18 PM Thread Starter
nick944's Avatar
nick944
Hyundai says PSF-3 is no longer made and any clear power steering fluid will work. Your manual actually says Dexron will work as a power steering fluid?
nick944 is offline
post #6 of 11 (permalink) Old 02-09-2010, 06:35 PM
jsinton's Avatar
Quoted: 69 Post(s)
Ok, I downloaded your owners manual, and it just says PSF-3.
My owners manual for a 1999 Elantra says PSF-3 or Dexron II.
I bought a bottle of Walmart Super Tech Power Steering Fluid last year. It has no designations or API specifications on the bottle. It's clear. I've been sucking out the reservior every few months and pouring in new fluid. I've had no ill effects for 20k miles. If it was wrong, I'd expect it to be noisy or leaking. It works fine.
It's up to you what you want to do, but if it was my car, I'd just buy the Walmart stuff and not worry about it.
jsinton is offline
post #7 of 11 (permalink) Old 02-11-2010, 01:19 AM
rsquared's Avatar
rsquared
Power steering fluid and ATF are both hydrauilc fluids. Back in the day...we used ATF for both. The difference between 3 and 4 is prolly the color. Adding color helps the techs find leaks easier.
There's never enough time to do it right, but there's always enough time to do it over.
rsquared is offline
post #8 of 11 (permalink) Old 02-11-2010, 01:26 AM
jsinton's Avatar
Quoted: 69 Post(s)
PSF 4 is a synthetic product. You can upgrade from PSF 3 to PSF 4, or even add PSF 4 with no problem. But you don't want to convert PSF 3 in a system that starts with PSF 4 as modern systems are not made to use it.
jsinton is offline
post #9 of 11 (permalink) Old 03-01-2010, 08:43 AM
rainshower
this is a service bulleten from hyundai,hope it helps
CHASSIS
07-50-002
FEBRUARY, 2007
ALL
PSF-4, HYUNDAI GENUINE POWER STEERING FLUID
DESCRIPTION:
This bulletin provides the PSF-4, Hyundai Genuine Power Steering Fluid, part number
and interchangeability information.
INTERCHANGEABILITY:
• PSF-4 to PSF-3 Topping off or adding up to 50% PSF-4 to a
PSF-3 system is acceptable.
NOTE: Do not add more than 50% of the total system volume of PSF-4 to
PSF-3. The PSF-3 fluid should be drained and replaced with PSF-4 power
steering fluid.
• PSF-3 to PSF-4 Not OK (Do not add PSF-3 to a PSF-4 system)
rainshower is offline
post #10 of 11 (permalink) Old 07-07-2012, 07:38 PM
04 Santa Fe V6 3.5 06 Sonata V6
woodie is an unknown quantity at this point
For the love of god,what's compatable with psf-3?
What is COMPATIBLE with PSF-3? I want to change it out myself, and if I can't get it all, I at least want to make sure that what I put in will mix properly with PSF-3.
woodie is offline
