Engine Swap 1.5 To A 1.6 - Hyundai Forums : Hyundai Forum
post #1 of 8 (permalink) Old 12-16-2009, 07:31 PM Thread Starter
damham
I have a 2001 Accent , blown head gasket cracked head. Its 1.5 L Can I swap in a 1.6 motor without having to do any modifications. Can has 5 sp manual transmission. If possible do iI need to swap out the ECU , any wiring issues? Thanks Dave
damham is offline
post #2 of 8 (permalink) Old 01-05-2010, 12:52 PM
reggofcal
QUOTE (damham @ Dec 16 2009, 04:31 PM)
I just got done switching a sohc (single over head cam) 1.5L engine out of my 99 hyundai accent.I put a 2001 dohc (dual over head cam)1.6L engine in.I had to do a lot of wiring but it runs fine. I dont think you will have as many problems as me as long as the motors are the same generation.
reggofcal is offline
post #3 of 8 (permalink) Old 01-16-2010, 08:34 PM
svt28
This is basically a drop in swap, i finnished it in a weekend on my g/f's 01, the only part i had to mod was a coolant temp sensor wire i had to extend, its probly one of the simplest swaps ever
svt28 is offline
post #4 of 8 (permalink) Old 01-18-2010, 04:05 PM
byama
Did you have to change the ECU? My daughters 2003 Accent 1.5l SOHC just seized and am wondering if I can swap the engine for a 1.6l DOHC. What other things do I need to be aware of?
byama is offline
post #5 of 8 (permalink) Old 01-19-2010, 12:21 AM
rsquared's Avatar
rsquared
QUOTE (svt28 @ Jan 16 2010, 08:34 PM)
How did you change your 1.5 MAF sensor to work with the 1.6 MAP sensor?
There's never enough time to do it right, but there's always enough time to do it over.
rsquared is offline
post #6 of 8 (permalink) Old 12-04-2012, 08:40 PM
Drives Accent
ajthib is an unknown quantity at this point
I did a similar swap. I have an 2001 Accent that came with a 1.5L but now has a 1.6L. Funny thing is, I bought a manual transaxle for a 1.5L and hook it up to the 1.6L engine. I have to throttle all the way up in order to shift now. Gears would slap and grind. Sometimes I couldn't even shift into gear. I thought maybe I put the new clutch in backwards, so I took it apart and it was in the right way. Clutch shows signs of uneven wear, and the teeth on the flywheel were scarred. Does anyone know what went wrong? It is a used transaxle so maybe its just bad. I may make a post of it.
ajthib is offline
post #7 of 8 (permalink) Old 12-04-2012, 08:52 PM
pare_john's Avatar
Quoted: 42 Post(s)
If the teeth on the flywheel are bad then there is an issue with your starter.
Sent from my iPhone using AutoGuide.com App
pare_john is offline
post #8 of 8 (permalink) Old 12-04-2012, 09:00 PM
Drives Accent
Yeah, it might be a separate problem. I'm still reading up on it right now and my next suspect is the speed sensor since the gear ratios between the 1.5 transaxle and 1.6 transaxle differ slightly.
ajthib is offline
