Wheel Bearings - Hyundai Forums : Hyundai Forum
post #1 of 3 (permalink) Old 04-10-2009, 08:45 PM Thread Starter
adamb_135
My front wheel bearings are going bad in my 1998 hyundai elantra and it's going to be about 500$ to get them changed by a shop, so I'm going to do it myself, anybody got any info on this?
and do i need to buy the wheel bearings or the complete hub assembly?
adamb_135 is offline
post #2 of 3 (permalink) Old 04-10-2009, 10:00 PM
shawn4547
Send a message via Yahoo to shawn4547
QUOTE (adamb_135 @ Apr 10 2009, 08:45 PM)
Its not a hub, Its a pressed in wheel bearing, You have have to have a slid hammer, an
a Press in order to do the job your self. Its not a very easy job, Not to bad if you got the
tools to do the job. Remove the wheel, Remove the two 17mm bolts holding brake caliper,
remove rotor, remove 32mm nut on axle, bolt slid hammer on spindle, use side hammer to
remove spindle, remove 17mm nut holding tie rod/hammer tie rod out, remove two bolts to hub to
stut, then remove 19mm lower balljoint nut/hammer out balljoint. Now you will have hub out Remove clip
from rear of hub an use press to press out bearing/press new bearing in an install clip back on rear. reinstall
above.
Shawn
shawn4547 is offline
post #3 of 3 (permalink) Old 04-11-2009, 07:12 AM
Drives 1.6 Lantra GSI Estate 2000 and also have a 1.6 Lantra GSI Saloon 1999
Quoted: 21 Post(s)
EdGasket
If you get the hub off the car, the easiest thing to do is to then get a garage to change the bearing itself. Just take in the hub and the new bearing and ask them to change it. My local garage (shop if you're American) charged £10 a few years ago for this but another wanted £20.
EdGasket is offline
