Hyundai Forums : Hyundai Forum (http://www.hyundai-forums.com/forum.php)
-   J2(1996-2000) Elantra & Lantra (http://www.hyundai-forums.com/j2-1996-2000-elantra-lantra/)
-   -   99' Elantra Trouble Codes (http://www.hyundai-forums.com/j2-1996-2000-elantra-lantra/96665-99-elantra-trouble-codes.html)
buckeyered 04-04-2009 03:47 AM
My check engine light is on so I stopped at autozone to use the reader
and this is what I received.
P1624 Factory manual control
P0713 Trans temp sensor
P0441 Evap emission control purge flow fault
Autozone didnt know what I needed or what they mean.
I have taken great care of my Elantra and it has served me well
and now has 115,000 miles. I have had all the recommended services done
on it over the last 10 years and it drives me nuts to see that check engine light on.
Any recommendations on what I need to do to clear the trouble codes is appreciated.
WillPartHyundai 04-05-2009 02:12 PM
QUOTE
[b]1999 > G 2.0 DOHC > ENGINE > G 2.0 DOHC > INSPECTION CHART FOR DIAGNOSTIC TROUBLE CODES
Fault Code No. / Comment / Component / MIL on
P0102[/color] / Mass air flow circuit low input / Mass Air Flow Sensor / Yes
P0103 / Mass air flow circuit high input
P0112 / Intake air temp. circuit low input / Intake Air Temperature Sensor / Yes
P0113 / Intake air temp. circuit high input
P0116 / Eng. coolant temp. circuit range / Engine Coolant Temperature Sensor / Yes
P117 / Eng. coolant temp. circuit low input
P118 / Eng. coolant temp. circuit high input
P0121 / Difference between load signal by MAF sensor and load signal calculated by TPS (MAF and TPS are not fault)
PO122 / TPS circuit low input / Throttle Position Sensor / Yes
P0123 / TPS circuit high input
P0130 / O2 sensor circuit malfunction / Upstream Oxygen Sensor / Yes
P0131 / O2 sensor circuit low voltage
P0132 / O2 sensor circuit high voltage
P0133 / O2 sensor circuit slow response
P0134 / O2 sensor circuit no activity detected
P0135 / O2 sensor heater circuit malfunction / Upstream Oxygen Sensor Heater / Yes
P0136 / O2 sensor circuit malfunction / Downstream Oxygen Sensor Heater / Yes
PO137 / 02 sensor circuit malfunction
PO138 / 02 sensor circuit high voltage
PO141 / 02 sensor heater circuit malfunction / Downstream Oxygen Sensor / Yes
PO201 / Injector cyl. 1, circuit malfunction / Injector / Yes
PO202 / Injector cyl. 2, circuit malfunction
PO203 / Injector cyl. 3, circuit malfunction
PO204 / Injector cyl. 4, circuit malfunction
__________________________________________________ __
P0300 / Random misfire detected / Non catalyst damage / Yes
P0301 / Misfire at cylinder 1 detected
P0302 / Misfire at cylinder 2 detected
P0303 / Misfire at cylinder 3 detected / Catalyst damage (you should repair immediately) / ing
P0304 / Misfire at cylinder 4 detected
P0326 / Knock sensor circuit range / Knock Sensor / No
P0335 / Crankshaft position sensor circuit malfunction / Crankshaft Position Sensor / Yes
P0336 / Crankshaft position sensor circuit range
P0342 / Camshaft position sensor circuit low input / Camshaft Position Sensor / Yes
P0343 / Camshaft position sensor circuit high input
P0422 / Catalyst efficiency, below threshold / Catalyst / Yes
P0442 / Evap. emission control system small leakage detected / Evaporative Emission Control System / Yes
[b]P0441 / Evap. emission control system purge valve permanently open
P0444 / Purge control valve circuit open / Evaporative Emission Control Valve / Yes
PO445 / Purge control valve circuit shorted
PO446 / Evap. emission control system canister close valve permanently closed / Evaporative Emission Control System / Yes
P0447 / Evap. emission control system, ventilation control valve, short circuit to ground / Canister Close Valve / Yes
PO448 / Evap. emission control system, ventilation control valve, short circuit to battery voltage
PO452 / Evap. emission control system, pressure sensor, signal low / Tank Pressure Sensor / Yes
PO453 / Evap. emission control system, pressure sensor, signal high
PO451 / Evap. emission control system, pressure sensor, signal not plausible
PO455 / Evap. emission control system incorrect purge flow / Evaporative Emission Control System / Yes
__________________________________________________ ______________________________
P0501 / Vehicle Speed Sensor Range / Vehicle Speed Sensor / Yes
PO506 / Idle rpm lower than expected / Idle Control Valve / Yes
PO507 / Idle rpm higher than expected
PO562 / System voltage low / Power Supply / Yes
PO563 / System voltage high
PO605 / Internal control module ROM error / ECM /Yes
P1123 / Long term fuel trim additive, air system too rich / Fuel System / Yes
P1124 / Long term fuel trim additive, air system too lean
P1127 / Long term fuel trim multiplicative, system too rich
P1128 / Long term fuel trim multiplicative, system too lean
P1510 / Idle control valve opening coil circuit shorted / Idle Control Valve / Yes
P1513 / Idle control valve opening coil circuit open
P1552 / Idle control valve closing coil circuit shorted
P1553 / Idle control valve closing coil circuit open
P1586 / Encoding signal circuit not rational / MT/AT Encoding / Yes
P1605 / Rough road sensor circuit malfunction / Acceleration Sensor / Yes
P1606 / Rough road sensor not rationale
P1611 / MIL request signal circuit low input / MIL-on Request Line / Yes
P1613 / MIL request signal circuit high input
As you can see, the first two codes are not even listed by hmservice.com
To be honest, I have never seen or got the first one (Factory manual control).
The second one is self-explanatory, obviously. You should check the sensor for faulty vaultage or just get a new one if is cheap and replace it.
Last one: maybe your purge valve just went belly up, or the contacts need some cleaning performed.
Powered by vBulletin® Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
