Bleeding Rear Brake - Hyundai Forums : Hyundai Forum
post #1 of 9 (permalink) Old 05-11-2005, 08:47 AM Thread Starter
Redfox835
How do you bleed the rear brakes on a 02 Elentra GLS? They are disk. Thanx
Redfox835 is offline
post #2 of 9 (permalink) Old 05-11-2005, 01:27 PM
duke's Avatar
duke
Thumbs down
your car has a "criss-cross" brake system; on none ABS brakes, the bleeding is done in the following way:
1st right rear, then left front, then left rear, then right front.
duke is offline
post #3 of 9 (permalink) Old 05-11-2005, 01:57 PM
ADMINISTRATOR
Montego's Avatar
Quoted: 98 Post(s)
you don't say why you need to bleed the rear brakes, have you disturbed the hydrolic system for any reason? if not lets have more details
MONTEGO
Montego is offline
post #4 of 9 (permalink) Old 05-25-2005, 10:21 PM
corfrosh
this thread hasn't moved in a bit, so i'm gonna hijack it a little. My rear, driver's side rubber brake line has a crack and needs to be replaced. I have a 2004 elantra gt with ABS.
I was hoping to do this myself, but the webtech site indicates the use of the hi-scan gizmo. Can i bleed these the old fashion way or should i not do it?
many thanks,
clayton
corfrosh is offline
post #5 of 9 (permalink) Old 05-26-2005, 08:55 AM
duke's Avatar
duke
No you can't. The ABS is in the circuit, and the pump needs to be switched on for proper bleeding, and this can only be done with the “Hi-scan”.
duke is offline
post #6 of 9 (permalink) Old 05-27-2005, 09:43 AM
ramblemn
Sigh.
Overzealous technology superscedes normalcy again.
I don't get it, brake fluid is STILL going to flow regardless of ABS, so why is anything electronic necessary?
ramblemn is offline
post #7 of 9 (permalink) Old 05-27-2005, 12:55 PM
ADMINISTRATOR
Montego's Avatar
Quoted: 98 Post(s)
this is true, in spite of what 'the book' says you can bleed the brakes in the normal way, this applies to almost all makes and models with abs
MONTEGO
Montego is offline
post #8 of 9 (permalink) Old 05-29-2005, 01:27 PM
corfrosh
ok, so who's right here? It makes sense that you could bleed them the normal way, but it also makes sense that if there's an ABS pump that gets air trapped in it, the air might not be able to be expelled unless the pump is running (ie: with a "hi-scan" tool)
hmmm,
clayton
corfrosh is offline
post #9 of 9 (permalink) Old 05-31-2005, 05:21 PM
ADMINISTRATOR
Montego's Avatar
Quoted: 98 Post(s)
bleed the brakes in the normal way they should be fine
MONTEGO
Montego is offline
