a faulty oxygen sensor - Hyundai Forums : Hyundai Forum
post #1 of 11 (permalink) Old 07-23-2004, 04:24 AM Thread Starter
jameson
Hi guys.......
i am the owner of 2000 Hyundai Lantra wagon.The most recent problem that occur with my car , has been a faulty oxygen sensor that caused the "check engine" light to come on. The dealer was apologetic and helpful when dealing with the problem.
jameson is offline
post #2 of 11 (permalink) Old 08-25-2004, 08:09 AM
nikki96
Hi, I a;so Have A 2000 Hyundai Elantra wagan, My cheak engine light was on I got a tune up then 2 days later it came back on again.Did they charge you,Because I know there have been some recalls on our car Please let me know.Thank You.
nikki96 is offline
post #3 of 11 (permalink) Old 08-31-2004, 11:49 AM
gordo
We had an engine light two days after a tune-up at the local dealership. - 2002 Elantra VE sedan.
For a day or so the car would down-shift for no apparent reason and then the engine started over-revving and the automatic transmission would not shift out of second gear. That's when the engine light came on.
After having the car towed in, the diagnosis was an arc-ing spark plug wire.
The mechanic said this would have caused the engine light to come on and all the problems as well. Warranty covered the tow.
Seems to be fine now
From Victoria BC
gordo is offline
post #4 of 11 (permalink) Old 09-01-2004, 08:41 AM
himanshu
Talking
get it!!!
himanshu is offline
post #5 of 11 (permalink) Old 09-03-2004, 03:41 PM
gordo
Well - another trip back to the dealer - similar problem, over-revving, shifting at the wrong times, can't use higher gears and now stalling and hesitating.
Dealer has now replaced the throttle position sensor - hoping this works.
Does this seem to be a common problem?
gordo is offline
post #6 of 11 (permalink) Old 10-29-2004, 11:41 AM
Ed H
The serpentine belt (runs the water pump and a few other things) on my 1998 Elantra Wagon just let go and the engine overheated. It was an easy repair (not a dealer) but the engine light came on and stayed on, despite the repair. The engine is running fine but the light was still on even after a couple thousand more trouble-free kms. For some reason the light went off when I let the gas tank run almost dry. It has stayed off since. Don't know what that means but it might be an easy way to get the pesky light off without a dealer visit.
Ed H is offline
post #7 of 11 (permalink) Old 05-30-2005, 07:27 AM
cbp officer
I have a 1997 hyundai elantra gls, check engine light goin on constantly, trouble codes indicate i think oxygen sensor problems, will find out on tuesday, droppin her off at the mechanics, car has 143000 miles on it
cbp officer is offline
post #8 of 11 (permalink) Old 05-30-2005, 12:20 PM
MikeNH's Avatar
MikeNH
Ed, a code can be set for an overheated engine, as for it being cleared by letting the gas tank get close to empty, I can't explain that
MikeNH is offline
post #9 of 11 (permalink) Old 01-03-2007, 03:19 PM
spydadee
1998 elantra se here! Check engine light goes on and off at will....no real problems with car....mechanic brother in law hooked it up to the diagnostics and said it was sumthin to do with the o2 sensors staying stuck open or closed....my car even passed an emission test with an engine light on so no big deal if its an o2 problem!
spydadee is offline
post #10 of 11 (permalink) Old 01-09-2007, 12:29 PM
Dragonmp5
Send a message via Yahoo to Dragonmp5
It's hard to believe you passed with an o2 sensor code considering it has to do with emissions. If you having a code with it just replace it.
Dragonmp5 is offline
