Using Clay Bar - Hyundai Forums : Hyundai Forum
post #1 of 19 (permalink) Old 03-21-2010, 07:04 PM Thread Starter
lovemysantafe's Avatar
Drives: 2012 Elantra Limited
Quoted: 73 Post(s)
It's a dirty world we live in and your car gets a good deal of abuse. Environmental conditions, industrial fallout, road tar, dirty rain...you name it, your car gets exposed to it on a daily basis. This write-up will get to the bottom of what clay bar is, what it does and doesn't do and how to use it properly.
What is clay bar?
Clay bar was developed by a Japanese inventor in the late 1980s as a way for automobile manufacturers to quickly and easily remove overspray from freshly painted cars without having to resort to wetsanding or repainting. It also makes a fantastic cleaning tool. The secret was picked up by professional detailers in the mid-1990s who tried to keep it all to themselves. However the good secrets don't stay that way for long and by the early 2000s, clay bar was available to the general public.
What does clay bar do?
The clay acts almost like dirt magnet, removing embedded contaminants that create a bumpy surface and prevent proper wax or sealant adhesion. When used properly with a spray lubricant (usually a quick-detailer), the clay picks up and locks in whatever might have latched onto the paint over the years. Because the dirt is suspended in the clay, it keeps it from micro-scratching the paint.
There are also a great number of myths about clay that have been perpetrated by detailers who didn't want their secret weapon in the hands of the public. Unfortunately, many of these myths remain. I will go through some of the most common misconceptions about claying here.
Myth #1 - I've been told that claying is inherently dangerous and can strip my paint off if not used by a professional.
FALSE - This is absolute baloney. Follow the instructions correctly and your grandmother could clay her car. It's very simple.
Myth #2 - I've heard that clay will eventually remove all of your clearcoat and because of that, can only be used every now and again
FALSE - Again...not true. The only thing that will remove small amounts of your clearcoat is polishing and even then, we're talking tenths of a micron (1 micron = 0.0000393"). Clay only removes contamination on the surface of your paint, leaving it perfectly clean for polishing and sealing.
Myth #3 - Clay can scratch your paint.
TRUE - Because clay is technically considered an abrasive cleaner, it can put micro-scratches into the clearcoat, more so on softer paint finishes. However most over-the-counter clay kits won't cause this and even if they do, these scratches are EXTREMELY shallow and can easily be polished out. If you are picturing some of those huge, deep scratches...you're wrong. Clay won't do that.
Myth #4 - Clay will remove oxidation and swirl marks.
FALSE - No...clay is only a cleaner. Oxidation and swirls can only be removed by machine polishing which will be covered at a later date.
Myth #5 - New cars don't need to be clayed / it is unsafe to clay a freshly painted car.
FALSE - This couldn't be further from the truth. Many new cars are shipped from their places of manufacture by rail and the rail cars have brake pads much like your car does. Every time the train brakes are used, little flecks of hot metal are sheared off the brake pad and fly into the air. Many of them wind up landing on the cars inside the autoracks and if left for years, they can undermine the clearcoat and cause rust. Also, cars are frequently stored outdoors in industrial areas for up to months at a time before being shipped to dealers and the environmental fallout definitely takes its toll on the finish. I clayed my new Santa Fe the day I brought it home and was astonished at what I picked up.
How-To: Start with a clean car by viewing the proper washing techniques thread. I strongly suggest working in the shade or in your garage if you have one. You will need a clay bar, a lubricant in the form of a car wash soap and water mixture or quick detailer and several clean microfiber towels. Because this is a very wet process, you will probably saturate three or four towels with quick-detailer.
Step 1: Make sure your hands are clean and free of wedding rings, etc.!!! Start with a clean piece of clay flattened out to about 3 to 4" (7 to 10 cm) across. If the clay is new or cold, it is liable to be very stiff. You can make it more mailable by working it with your hands or by putting in a plastic bag and then submerging the bag in a bowl of warm water. It's up to you.
Step 2: Spray a liberal amount of your quick-detailer on the panel in question.
Step 3: Start from the top of the panel and work your way down, going left to right. When you get to the bottom, work your way left to right again but in an up-and-down motion. The entire job should be done in a cross-hatch pattern. Panels that are large or very contaminated can be passed over several times. If your clay gets hung up, keep the surface well-lubricated.
If you feel a gritty or rough sensation through the clay, don't panic! The clay is simply doing its job and removing nasty unwanted crap from your paint.
This is what clay looks like when all the contaminants are trapped inside it. When you get one side dirty, simply fold it over several times until you get a clean section. Clay should be thrown out when it gets worn (begins to tear, etc.) or if it gets dropped on the ground. DO NOT use clay that has fallen on the ground. Immediately throw it out and get a new piece!
Once you are done claying a panel, wipe off the excess lubricant and do not let it dry on the paint. Hopefully this is helpful to everybody.
Andrew
Titanium Gray / Gray Leather
Last edited by lovemysantafe; 09-22-2011 at 08:03 PM. Reason: Corrected Formatting
lovemysantafe is offline
post #2 of 19 (permalink) Old 03-21-2010, 11:42 PM
ausom accent 9's Avatar
2009 Accent SE
ausom accent 9 is an unknown quantity at this point
Great job & by the way, I wish I had a nice garage like yours
ausom accent 9 is offline
post #3 of 19 (permalink) Old 05-09-2010, 06:14 PM
ThunderLizard's Avatar
ThunderLizard
Great write-up on an item that's been a mystery to me for years!
BTW - looks like those windows in the back of your garage could use some clay-lovin! (a-la-overspray?) Ha!
ThunderLizard is offline
post #4 of 19 (permalink) Old 06-17-2010, 04:40 PM
sailpowerd
lovemysantafe you mentioned at Myth #3 - Clay can scratch your paint.
TRUE - Because clay is technically considered an abrasive cleaner, it can put micro-scratches into the clearcoat, more so on softer paint finishes. However these scratches are EXTREMELY shallow and can easily be polished out. If you are picturing some of those huge, deep scratches...you're wrong. Clay won't do that.
Does this mean that if you clay your new car that you must polish out the minute scratches? If yes does this mean you must use a buffer to do this or will had polishing/waxing by hand remove these scratches. Or are these so minute that they are of no consequence.
Thanks, lee
sailpowerd is offline
post #5 of 19 (permalink) Old 06-19-2010, 11:26 PM Thread Starter
Quoted: 73 Post(s)
Hi Lee...
I should have been clearer. It can put minor scratches in the paint but using mild clay shouldn't give you this problem. Most OTC clay kits won't have any adverse effects on your finish.
Andrew
post #6 of 19 (permalink) Old 06-21-2010, 12:40 PM
sailpowerd
QUOTE (lovemysantafe @ Jun 19 2010, 11:26 PM)
Hi Lee...
Thanks for all the info you have provided.
post #7 of 19 (permalink) Old 03-25-2011, 05:52 PM
bishi
I've only had my Sonata 4 days and I DO NOT want to @#%$ it up. Just ordered some weathertech mats for the inside and now am worried about the exterior.
How often should the clay be used? And what about waxing?
bishi is offline
post #8 of 19 (permalink) Old 05-11-2011, 10:19 AM
CDot
QUOTE (bishi @ Mar 25 2011, 05:52 PM)
For the clay bar: Some people will tell you different things, but you should be ok with once a year. Or (if you are particular), do it twice a year--I recommend once at the end of winter to get all the winter gunk off, and once at the end of summer/early fall after it's been pelted with bugs/bird crap.
For waxing: That depends on what type of wax you want to use and how often you want to wax. And it depends on what you're looking for in a wax (durability vs. protection vs. shine/looks). I have my recommendations depending on what you want.
CDot is offline
post #9 of 19 (permalink) Old 05-11-2011, 10:27 AM
CDot
Has anyone tried plain warm, filtered water to clay with? I've done this before and it seems to give the exact same results, but without using up all my quick detailer spray. Saves me money in the long run.
CDot is offline
post #10 of 19 (permalink) Old 08-19-2012, 09:54 PM
2013 Elantra GT Titanium Gray Metallic Style & Tech Packages
egore24 is an unknown quantity at this point
Great job! Could someone post a link to the proper washing techniques thread? Or better yet, is there a start to finish thread that covers all steps to do the most complete auto detailing job? If there isn't such a thread, maybe we could link each thread that covers other topics (washing, claying, polishing, waxing, black plastic protection/bringing back to life, window washing, etc) into a central thread?
Thanks much!
egore24 is offline
