 Hyundai-Forums.com > Hyundai Models > Santa Fe Forum > 1G (2001-2006) Santa Fe
> 2004 Fog Light Bulb Replacement How-to
Garrin
post Nov 3 2009, 12:01 AM
Post #1
Newbie
Group: Members
Status: Offline
Drives: 2004 Hyundai Santa Fe 4cyl
Hi, hope you're all doing well.... I've looked over my 2004 Santa Fe trying to figure out how to access the Fog Lamp Bulbs to replace them but nothing sticks out to me other than removing the bumper.... if anybody has any experience with this I would love to hear from you.
Thanks for your help and time.
Garrin
Go to the top of the page
+Reply
lovemysantafe
post Nov 3 2009, 06:14 AM
Post #2
Just a little bit closer.....
Group Icon
Group: Moderator
Status: Offline
Drives: '04 Santa Fe GLS 4WD (Born 5.24.04)
Ugh...I had a whole write-up written here and accidentally clicked the 'X' on the tab before I could post it. (IMG:style_emoticons/default/angry.gif) Oh well...not your fault. Here it is.
Thankfully you do not have to remove the bumper. Here is a step-by-step for you to follow. It's been about two years since I toyed with mine so this may not be 100% but it's pretty darn close. (IMG:style_emoticons/default/thumbsup.gif)
  1. Remove the headlamps - they use a 10 mm socket
  2. Reach down into the bumper and disconnect the power leads to the bulb. The release tab is on top of the connector, covered by some insulating foam. No need to remove the foam, just push the tab through it and slide the connector off.
  3. Turn the bulb socket counterclockwise to remove it from the fog light assembly.
Once you replace the bulb, make sure you don't touch it with your fingers. Re-installation is not easy and avoiding contact with the bulb is even trickier so just be patient and take your time. Fitting the new bulb in the socket can be nearly impossible if you're looking down from the top because its very difficult to see how the notches line up. Luckily, I found a solution. With the new bulb in your hand, reach down and put it halfway into the socket, then (without letting go) look through the fog light lens and you'll be able to see how the notches line up. This is SOOO much easier than trying to do it blindly.
Reconnect the power leads and test them before zipping everything back up. Good luck and I hope these instructions are helpful!! (IMG:style_emoticons/default/thumbsup.gif)
+Reply
Garrin
post Nov 3 2009, 12:29 PM
Post #3
Newbie
Group: Members
Status: Offline
Thank you, I'll give that a shot this weekend (IMG:style_emoticons/default/smile.gif)
+Reply
EF/ELP
post Nov 7 2009, 12:08 AM
Post #4
Member
Group: Members
Status: Offline
Drives: 2004 Sonata LX
And while you are at it go for the upgrade on the lights, I installed this
http://www.v-leds.com/Exterior-LED/DRL-LED...D-p7652845.html
On my 2004 Sonata and pair very nice with the HIDs.
Good luck.
+Reply
  Advanced Search
0 Members:
Collapse
> Similar Topics
No New Posts Fog Light To Hid Problem
1 ziggsta 13 Today, 01:11 AM
Last post by: boostedfc3s
No New Posts Lighting For Homelink !
why is the mirror not lit
8 TLSRULZ 224 Yesterday, 07:31 PM
Last post by: congo
No new Foglight Independent Of Headlights - Fixed!
47 MajBach 1,716 18th November 2009 - 06:09 PM
Last post by: gamoneda03
No new Pinned: Topic has attachmentsReplacement Dvd/gps/tv/bluetooth Unit
625 glospete 37,406 8th November 2009 - 01:46 PM
Last post by: villmones
No New Posts 2004 Turns But Won't Start. (fuel Problem?)
Bogus obd code as well (P2407)
4 Cughter 111 6th November 2009 - 04:31 PM
Last post by: Cughter
21st November 2009 - 09:37 AM
Privacy Statement
