 Hyundai-Forums.com > Hyundai Models > Accent Forum > 3G (2006+) Accent
> Oil Change - 2009 3g, Anyone interested in a oil change step by step
RonKall
post Nov 2 2009, 04:30 PM
Post #1
Newbie
Group: Members
Status: Offline
Drives: 2009 Accent GS3
Even with the full shop manual, there is no step by step on the oil change. Plus the factory oil filter was really put on tight.
Go to the top of the page
+Reply
bloodninja
post Nov 2 2009, 05:22 PM
Post #2
Veteran
Group: Members
Status: Online
Drives: 2008 Hyundai Accent SE (4-speed Auto)
If you really want to make one I guess you could. It's so stupidly easy lol.
+Reply
Dirk_Gently
post Nov 2 2009, 09:46 PM
Post #3
Member
Group: Members
Status: Offline
Drives: 2008 Hyundai Accent GS
QUOTE (RonKall @ Nov 2 2009, 04:30 PM) *
Filter wrench ftw (IMG:style_emoticons/default/thumbsup.gif)
+Reply
dafunk
post Nov 2 2009, 10:02 PM
Post #4
Full Member
Group: Members
Status: Offline
Drives: 2009 Hyundai Accent GS 1.6, 1988 Honda CRX 1.5, 1989 Honda Civic 1.5, 1991 Honda CRX Si 1.6
Just stab a screw driver through it and turn. Doing things the right way is for sissies. (IMG:style_emoticons/default/bwekk.gif)
+Reply
0.o slow 1.6
post Nov 2 2009, 11:08 PM
Post #5
Full Member
Group: Members
Status: Offline
Drives: MC accent
Your guys are sissy for not being able to take it off with your hand. GOT YA!!! lol I kid I kid. (IMG:style_emoticons/default/bwekk.gif)
+Reply
PaCHeKo!
post Nov 3 2009, 01:48 AM
Post #6
Senior
Group: Members
Status: Offline
Drives: 2007 Hyundai Accent SR
That would be awesome!
+Reply
RonKall
post Nov 6 2009, 05:25 PM
Post #7
Newbie
Group: Members
Status: Offline
Oil Change
Use 5w20 oil
3.45 qts with filter change
warm the engine ten minutes at idle or hot from driving
shut the engine off
turn wheel full right - gives you a space to work on the drain plug
jack up car on passenger side front jack point about half way up the jack
remove side guard plastic in the wheel well - 2 bolts 10mm
remove lower plastic guard 6 bolts 12mm
drain plug is on the passenger side rear of the oil pan
loosen oil fill cap
remove drain plug 17 mm and gasket - steel washer
discard gasket
lower car on jack stand to minimum
let the oil drain
replace drain plug with new gasket and torque to 35 NM
move drain pan to under oil filter
jack the car back up
remove oil filter
lower the car on jack stand
coat new oil filter rubber gasket with clean oil
replace oil filter 15 NM or hand tight plus half turn
add oil - 3.4 qts.
check for leaks
+Reply
jsinton
post Nov 6 2009, 05:51 PM
Post #8
Veteran
Group: Members
Status: Online
Drives: 1999 Elantra
QUOTE (dafunk @ Nov 2 2009, 10:02 PM) *
Don't do that, sometimes they just rip off the sheet metal and leave the filter base on there. Then what do you do?
Do yourself a favor and go out and buy a socket type filter wrench, works like a charm, never fails.
+Reply
bloodninja
post Nov 6 2009, 06:20 PM
Post #9
Veteran
Group: Members
Status: Online
QUOTE (jsinton @ Nov 6 2009, 05:51 PM) *
lol
+Reply
DalwinCo
post Nov 6 2009, 06:23 PM
Post #10
Veteran
Group: Members
Status: Offline
Drives: 2007 Hyundai Accent SE 1.6
QUOTE (Dirk_Gently @ Nov 2 2009, 08:46 PM) *
+1
QUOTE (0.o slow 1.6 @ Nov 2 2009, 10:08 PM) *
Lol. That kinda made me chuckle.
+Reply
  Advanced Search
0 Members:
Collapse
> Similar Topics
No New Posts 2009 Elantra Touring Gl: Radio Problems
FM Presets + Power-on volume setting forgotten
2 y-man 17 Today, 06:47 PM
Last post by: montego
No New Posts Oil Control Valve
Really needed?
0 samkent 12 Today, 08:09 AM
Last post by: samkent
No New Posts 2009 Azera Infiniti Display
Blank Display in Cold Weather
0 bm02072 48 Yesterday, 12:49 PM
Last post by: bm02072
No New Posts Oil Viscosity?
2 Boroboy 140 17th November 2009 - 07:27 PM
Last post by: Boroboy
No New Posts Change Plastic Engine Cover On A 2001 To 2003 Cover
2 doggie71 38 17th November 2009 - 04:52 PM
Last post by: lovemysantafe
20th November 2009 - 10:42 PM
Privacy Statement
