 Hyundai-Forums.com > Hyundai Models > Accent Forum > 1G (1995-1999) Accent
> Tach, installation
cuban
post Oct 28 2009, 02:00 PM
Drives: 1996 hyundai accent 1.5l custom catback, custom cai, stripped interior, new clutch, more to come....
I have a 96 accent 1.5l and want to install a tach. I hooked it up to the coil but wont rev over 3000 and thats even putting it to the floor. Any help would be greatly appreciated.
atrain
post Oct 28 2009, 07:40 PM
Drives: 1999 Hyundai Accent
universal tachs have different settings for different # of cylinders. What is it showing you at idle? (Should be around 800ish I think.)
cuban
post Oct 28 2009, 08:00 PM
There is a setting 4,6,8. I have it set at 4 and it revs around 700 or 800 rpm. At max rev it shows 3000 in gear or neutral, pedal to the floor. I have installed tons of guages in other vehicles but never a tach in a hyundai.
mac1
post Oct 28 2009, 09:42 PM
Drives: 2001 XG, '01 Accent 1.6L, '96 Accent, '95 Probe GT-Turbo weenie
well since no one else has pointed it out, guess i'll be the first. And let me know if it works as i'm gonna do the same. Do you have an auto or stick? pin 52
(IMG:http://hmaservice.com/data/Passenger/HY/HMA/ENG/SHOP-Images/HY-X313-IMAGES-ENG/A5SD112B.gif)
This post has been edited by mac1: Oct 28 2009, 09:43 PM
cuban
post Oct 28 2009, 09:48 PM
I have the five speed. The instructions said to look for pin 52 and its green yellow/white wire. Founds tons of them but I guess not the right one.
mac1
post Oct 31 2009, 12:44 AM
remove the connector from the ecm, undo the plastic housing so you can see the wires going into the pins. Now turn it around so you see the side that connects to the ecm and count from right to left starting at upper right corner. Count 52 pins over and see if it lands on that wire. If you're not sure what side of the connector is upper right then try it a few times till you land on the correct pin number and wire color. And since yours is a a stick with no TCM that means it will probobly be white.
This post has been edited by mac1: Oct 31 2009, 12:45 AM
understated
post Nov 7 2009, 03:36 AM
Drives: 1996 Hyundai Accent/Excel X3
On the ECU pin the RPM signal wire is the 6th pin from the right (with the plug facing away from you) on the top row, the row with 19 pins (both other rows of pins have 18). I suspect you have the wrong signal wire.
No New Posts 1996 Excel Sprint Tacho Wiring
1 AdamLang_100 27 16th November 2009 - 05:46 PM
Last post by: sanjeet
No New Posts Anyone Know What Controls The Tachometer
1 cltrailer 87 15th November 2009 - 12:55 PM
Last post by: ebmf
No New Posts Jumpy Tachometer
0 ebmf 20 15th November 2009 - 12:50 PM
Last post by: ebmf
No New Posts Tachometer
8 Beverley 275 25th October 2009 - 04:06 PM
Last post by: wrighty
No New Posts Need Some Help To Hook Up A Tach In Excel 1999
1 hero6489 197 15th October 2009 - 09:44 PM
Last post by: beanz
21st November 2009 - 12:33 AM
