 Hyundai-Forums.com > Hyundai Models > Elantra & Lantra Forum > 2G (1996-2000) Elantra & Lantra
> Coolant Trouble, Head gasket? or Heater Core?
schellmis63
post Oct 26 2009, 03:40 PM
Post #1
Newbie
Group: Members
Status: Offline
Drives: 2000
My car has had a few issues and I hope that someone can give me some help. My hyundai Elentra 2000 seems to continue to over heat after running the car on the road. The car sits and idles and does not over heat, however I can hear coolant boiling in the engine. I was told that this could be a blown head gasket however the only sign of this is the car is over heating, when the radiator cap is over, water will begin to boil out of the radiator. Also the car is not producing hardly an heat in the cabin, even when the car is at running temperature. Many times the cabin heat is very cold then also it will function back to warm. There is no white smoke, no fluid in the oil. No sign of oil or leaks from the spark plugs.Things that I have done, changed the thermostat, new radiator cap, radiator flush and new water pump, radiator had been burbed. After doing all this, the car still over heats,when the gage is running high, I can hear again the coolant bubbling in the engine. When the car is running very hot near the red line, the car radiator cap shows steam and coolant bubbling back into the reseviour. I know that a pressure test is needed but has anyone had or seen these symptoms and could this very well be a blow head gasket? Letting only combustion into the coolant, which is causing the over heating? and loss of warm air in the cabin? Also the car is running great! No signs of any trouble at all. No rough idle or running.
Go to the top of the page
+Reply
montego
post Oct 26 2009, 03:49 PM
Post #2
Administrator
Group Icon
Group: Administrator
Status: Online
Drives: XG's (2001&2002)
it sounds like you have done everything, and yes l agree it does seem now that the head gasket has blown, as you say it needs to have a pressure test to confirm this. try running the engine with the rad. cap off, if water is being forced out of the top of the rad. then its almost certain to be the gasket
+Reply
schellmis63
post Oct 26 2009, 04:10 PM
Post #3
Newbie
Group: Members
Status: Offline
Drives: 2000
With the radiator cap off, how long should it take to over heat if the head gasket was blown and with the radiator cap off and its not the head gasket how should the coolant act? Will I see any bubbles or over flow? Also one more question,,, well there might be a few more.. Will this type of blown headgasket, lead to coolant and oil mix in the near future? Also since this car may not be fixable, or worth it... How about the Bar's gasket fix? Where you put it in the antifreeze without draining it? I can't afford a replacement and I do hate to trash the car, its been really good to me and still has the figure of a new car!
This post has been edited by schellmis63: Oct 26 2009, 04:15 PM
+Reply
montego
post Oct 26 2009, 04:15 PM
Post #4
Administrator
Group Icon
Status: Online
just run the engine for a few mins. if there is excess pressure (blown gasket) water will soon blow out of the rad.
+Reply
schellmis63
post Oct 26 2009, 04:26 PM
Post #5
Newbie
Group: Members
Status: Offline
Drives: 2000
Thanks Montego, I am going to let the car run now,,let you know the outcome!
+Reply
schellmis63
post Oct 26 2009, 04:45 PM
Post #6
Newbie
Group: Members
Status: Offline
Drives: 2000
Results, Let car run about 10 minutes. Engine was warm to touch, hoses getting hot. I watched the coolant start to flow over the radiator opening but no bubbling over.. Also no air pockets coming out. This engine was cold when I started this, for its been sitting for a week.
+Reply
montego
post Oct 26 2009, 05:53 PM
Post #7
Administrator
Group Icon
Status: Online
your results are inconclusive, you must get the car to a garage and ask them to pressure test the system, this should not cost much.......let us know your results
+Reply
  Advanced Search
0 Members:
Collapse
> Similar Topics
No New Posts Topic has attachmentsCoolant Temperature Sensor Location
Please Help!
2 santafesuv 47 19th November 2009 - 04:54 AM
Last post by: santafesuv
No New Posts Coolant Issues
Radiator
5 01 Blue Shark 68 5th November 2009 - 03:19 PM
Last post by: 01 Blue Shark
No New Posts Coolant Change
6 U-96 210 26th October 2009 - 07:58 AM
Last post by: U-96
No New Posts Troublecode P0715 And P1529
Reason for Check engine light on.
22 rdodson4 14,829 14th October 2009 - 03:53 PM
Last post by: fbod383
No New Posts Coolant Level Too High
5 brendanq 162 7th October 2009 - 09:18 PM
Last post by: rsquared
21st November 2009 - 01:59 PM
Privacy Statement
