 Hyundai-Forums.com > Hyundai Models > Elantra & Lantra Forum > 2G (1996-2000) Elantra & Lantra
> Is My Ignition Coil Bad?
ElantraBoy98
post Oct 24 2009, 12:13 PM
Post #1
Member
Group: Members
Status: Offline
Drives: 1998 Elantra Base
I've been getting uneven idle. New plugs, new wires, clean throttle, clean IAC, clean MAF. No misfire codes.
Tested coil resistance (cold engine):
Primary:
bet 1/3 : 0.9 ohms
bet 2/3 : 0.8 ohms
Secondary:
bet 1/4 : 10.3 K
bet 2/3 : 10.3 K
hmaservice specs:
primary - 0.5 ohms +/- 0.05
secondary - 12.1 K +/- 1.8K
The resolution on my multimeter is 0.1 ohm at the lowest range setting of 200 ohm. When I short circuit the test leads, my reading is 0.1 ohm.
The primary resistances are above the high end of the spec range but they are about even with eachother.
The secondary resistance is exactly at the low end of the spec range.
Go to the top of the page
+Reply
99son
post Oct 27 2009, 01:51 PM
Post #2
Newbie
Group: Members
Status: Offline
Drives: 1999 sonata 2.4L
doesnt seem as though it is from the readings you gave. are there any other tests that should be done that are given in the manual? Sorry used to working on motorcycles.
think I am remembering one other test tho.
+Reply
EdGasket
post Oct 28 2009, 01:40 PM
Post #3
Full Member
Group: Members
Status: Offline
Drives: Hyundai Lantra GSI 1.6 2000
I had uneven idle; resetting the ecu fixed it. Baiscally just disconnect the battery or pull the ECU fuse, step on the brake pedal to discharge any capacitors, leave for 15 minutes to make sure, then reconnect. If that doesn't work, test the throttle position sensor with your voltmeter.
+Reply
  Advanced Search
0 Members:
Collapse
> Similar Topics
No New Posts My Santa Fe...
is more reliable than..
0 Pinto_Siftbean 21 Yesterday, 08:04 PM
Last post by: Pinto_Siftbean
No New Posts My Baby Is Getting Old!
7 v33sonata 198 Yesterday, 03:49 AM
Last post by: delhiboy3732
No new Topic has attachmentsMy Whip
26 RobPecnick 323 18th November 2009 - 02:55 PM
Last post by: RobPecnick
No New Posts My New Shoes
6 msvg 906 18th November 2009 - 12:01 PM
Last post by: JohnIrvine1
No New Posts Topic has attachmentsMy New Beast
2007 Elantra SLX
7 baddad76 1,217 18th November 2009 - 11:52 AM
21st November 2009 - 12:38 AM
Privacy Statement
