QUOTE (legendofkeele @ Oct 23 2009, 10:21 AM)
I recently bought 2009 Hyundai Santa Fe GL 2.7, it has the tire size of 235/70/16R. Can sombdy help me in suggesting which tire size would give me more miles than the suggested miles per gallon ie., 24 m/gal.
thanx for all the suggestions.
(IMG:
style_emoticons/default/smile.gif)
225/75s should help...
215/85s would rock if it weren't for them weighing 40+ pounds instead of 30.
The best thing you can do is get a ScanGauge so that you get immediate feedback for all phases of your driving. You get nothing idling excessively, it sucks getting up to speed (3-9mpg), but once your into top gear (4th for you, 5th for me) at lower speeds you're laughing. Don't be afraid to use the manumatic to upshift before intended upshifts and use it to lose speed and even shut off the fuel injection. The tranny has a warranty, brakes don't and just make heat.
Get into top gear and stay in top gear and minimize speed changes and keep it on the flats cause these move a lot of weight up and down the hills.
I may go for slightly taller (and possibly narrower) tires at some point along with the Eibach springs because the Santa Fe really isn't sprung for downhill twisties with dips in them and I'm reminded off that every time I come back over the mountains from Santa Cruz.
Tires are a highly debated matter around here, but I find the Santa Fe rolls far better with more air in the tires, and easier rolling translates into a lesser load for the engine. Use common sense and also read up on this.
Use the other car if it is more efficient. I take the TSX if it isn't the full family or I need the space or the other car is out. Especially to Santa Cruz where you have to climb and then brake or downshift all the way down the other side of the mountains. Paddle shifters rock for that.
Santa Fe rocks when we have a full back seat or doing airport duty.
I'd rather have a 4 banger wagon with a stick (or diesel sportwagon) but I want to have a ton of legroom for me and enough for a tall kid in behind me and can't afford a German E series or 5 series wagon. It also should fit a 65cm bike inside the back so it is lockable in a pinch with the wheels left on (for convenience).
This post has been edited by UniR: Oct 24 2009, 05:52 PM
