 Hyundai-Forums.com > Hyundai Models > Santa Fe Forum > 2G (2007+) Santa Fe
> On Demand Awd Vs Awd (3.3 Santa Fe 2009)
K.G
post Oct 16 2009, 09:30 PM
Post #1
Newbie
Group: Members
Status: Offline
Drives: Honda Accord,2009 Santa Fe GLS FWD
What is the difference bettween ON DEMAND AWD and AWD??
Also have heard that AWD does not work under 35km/hr....if true then does it become FWD over 35km/hr???
I might me wrong on all this but want to know how it works on 2009 santa fe 3.3
thanks
This post has been edited by K.G: Oct 16 2009, 10:10 PM
Go to the top of the page
+Reply
Volfy
post Oct 16 2009, 10:44 PM
Post #2
Expert
Group: Members
Status: Offline
Drives: 2007 Veracruz Limited
QUOTE (K.G @ Oct 16 2009, 09:30 PM) *
thanks
Check out the pinned thread on the SF AWD system titled: Santa Fe's All Wheel Drive System Information Here.
+Reply
K.G
post Oct 16 2009, 10:55 PM
Post #3
Newbie
Group: Members
Status: Offline
A button on the dash can lock the clutch to provide 50% torque to the rear wheels, but this only occurs below 35 kph. Above that speed, the computer pulses the solenoid to disengage the clutch mechanism, but it will automatically engage it again when vehicle speed lowers.
Does this mean that above 35km/hr it reverts to FWD and below 35 its AWD???
+Reply
MalagaMan
post Oct 17 2009, 02:29 AM
Post #4
Member
Group: Members
Status: Offline
Drives: Santa Fe CDX+ 2.2CDi
QUOTE (K.G @ Oct 17 2009, 05:55 AM) *
Yes, above 35km/h it is FWD, and below that speed all four wheels are driven - when the manual over-ride button is pushed.
So summarising:
The vehicle normally drives as a FWD.
When a front wheel(s) slip e.g. sand, snow, the rear wheels receive torque and then all four wheels are driven. This all happens below 35km/h.
Much of the confusion derives from the acronym AWD, which is ambiguous, in that it could be Full Time or Part Time All Wheel Drive.
So for example we know that a Range Rover has all four wheels driven all the time, whereas most modern small to medium SUV's have a part time system.
This post has been edited by MalagaMan: Oct 17 2009, 02:33 AM
+Reply
Pinto_Siftbean
post Oct 17 2009, 06:11 AM
Post #5
Senior
Group: Members
Status: Online
Drives: 2008 Santa Fe 3.3 Limited
QUOTE (K.G @ Oct 16 2009, 10:30 PM) *
thanks
The button on the dash has been explained for low speeds and AWD, but most "AWD" vehicles are on demand. It detects wheel slippage and then sends power to that wheel or wheels when needed. Hyundai is simply called AWD.. Honda Real Time AWD and so on. Even the subie's I've had that were automatic transmissions were an on-demand system really... at hiway speeds they were at least 90% FWD until slippage was detected.
This post has been edited by Pinto_Siftbean: Oct 17 2009, 06:12 AM
+Reply
Dino Kirov
post Oct 23 2009, 03:15 PM
Post #6
Member
Group: Members
Status: Offline
Drives: Santa Fe 2008 4WD 2.2CRDi Comfort trim.
Only the 4WD LOCK (AWD LOCK) mode is up to 40kph. The AUTO mode (90:10 to 50:50 torque split) is ALWAYS ACTIVE. This means that if at 100kph the computer decides that you need torque on the rear wheels it will send power there. And something more, the ITM 3e magnetic clutch ALWAYS sends at least 10% of the power back.
+Reply
Don67
post Oct 24 2009, 04:22 AM
Post #7
Expert
Group: Members
Status: Offline
Drives: 2008 Santa Fe 3.3 AWD
Auto AWD mode is really all you need, but some of us obsessive types like to engage "Lock" when playing in the snow just to eliminate that short (some would say imaginary) gap before the rear wheels dig in. "Lock" is also helpful when pulling a camper up gravelly hills in campgrounds, to avoid those scratchy front-wheel burnouts which earn you dirty looks from your neighbours as they pull their children closer.
+Reply
CanuckGLS
post Oct 24 2009, 11:38 AM
Post #8
Full Member
Group: Members
Status: Offline
Drives: 09 Sante Fe GLS AWD, '98 SVT Cobra 'Vert
QUOTE (Don67 @ Oct 24 2009, 05:22 AM) *
LOL....good one, Don!
+Reply
UniR
post Oct 24 2009, 05:59 PM
Post #9
Expert
Group: Members
Status: Offline
Drives: '07 SF 3.3AWD
QUOTE (Don67 @ Oct 24 2009, 04:22 AM) *
In deep snow*, I find the handling to feel more finicky with AWD locked. The back end seems to be "busy" rather than dutifully following the tracks of the front wheels. It doesn't feel dangerous locked but to me it doesn't feel nearly as secure.
*For example a residential street with 8" of light to wet snow before the plows have arrived.
+Reply
Don67
post Oct 25 2009, 06:44 AM
Post #10
Expert
Group: Members
Status: Offline
QUOTE (UniR @ Oct 24 2009, 06:59 PM) *
Must be that San Jose snow since you moved, UniR (IMG:style_emoticons/default/smile.gif)
My preference for Lock mode is probably based on a heavier right foot, where Auto mode produces more pronounced front wheel slippage followed by a more abrupt transition to 50/50 AWD. But under light to moderate wheelspin you are definitely right... Lock mode causes more rear-end squirm since it goes 50/50 rather than preserving a front wheel bias.
+Reply
AlaskanAWD
post Oct 25 2009, 10:48 AM
Post #11
Member
Group: Members
Status: Offline
Drives: 2008 Santa Fe Limited AWD
QUOTE (Don67 @ Oct 25 2009, 03:44 AM) *
In the winter, lock mode also helps on sharp swithback corners where the inside wheels have slippage. I live on the side of a mountain where our roads follow the natural contours with lots of corners, lock mode makes a big difference.
+Reply
  Advanced Search
0 Members:
Collapse
> Similar Topics
No New Posts 2009 Elantra Touring Gl: Radio Problems
FM Presets + Power-on volume setting forgotten
2 y-man 15 Today, 06:47 PM
Last post by: montego
No New Posts Santa Fe Tires Wanted
0 quintain 3 Today, 05:42 PM
Last post by: quintain
No new Santa Fe With Beige Interior Came With Dark Charcoal Floor Mats?!?!
24 Counselor4444 444 Today, 06:22 AM
Last post by: Don67
No New Posts Ferrari 250 Tr Gets Airborn At Monterey 2009
3 trev0006 476 Yesterday, 11:32 PM
Last post by: Mini-Beast
No New Posts 2009 Azera Infiniti Display
Blank Display in Cold Weather
0 bm02072 47 Yesterday, 12:49 PM
Last post by: bm02072
20th November 2009 - 09:05 PM
Privacy Statement
