QUOTE (kody @ Oct 12 2009, 09:36 PM)
How do I remove the bezel around the stereo on a 2002 Hyundai Accent?
It's pretty simple...yet complicated. (IMG:
style_emoticons/default/grin.gif)
I start by removing the lower dash assembly, then I empty & lower the glove box. Remove the cable behind the glove box and both cables by the gas pedal. Partially open the cup holder and remove the two screws. Once this is done the center section just unsnaps. Go easy, starting at the bottom. You still need to unplug the a/c switch & blower moter switch, then the rear defrost, hazard & fog light switch. At the top is the clock. You may not have all this...just pull the assembly out about an inch and look for wires. Don't force anything. And with an a/t set the park brake cause you'll need to put the tranny in low gear. This makes it easier when you pull the center dash out. (IMG:
style_emoticons/default/thumbsup.gif)
I feel like I'm missing something. If you have any questions let me know.
This post has been edited by rsquared: Oct 12 2009, 11:09 PM
