 Hyundai-Forums.com > Hyundai Models > Santa Fe Forum > 1G (2001-2006) Santa Fe
> Coolant Change
U-96
post Oct 12 2009, 09:51 AM
Post #1
Member
Group: Members
Status: Offline
Drives: 2003 Santa Fe 2.7
The coolant change procedure from the owners manual sounds a bit esoteric:
3. ...Then, following the manufacturer's directions on the engine coolant container, add the appropriate quantity of coolant to the radiator.
4. Turn the radiator cap counterclockwise without pressing down on it, until it stops. This relieves any pressure remaining in the cooling system. And remove the radiator cap by pushing down and turning counterclockwise. Now fill the radiator with clean demineralized or distilled water. Continue to add clean demineralized or distilled water in small quantities until the fluid level stays up in the radiator neck.
5. Start the engine, top off the radiator with water and then add coolant to the reservoir until the level is between "L" and "F".
Is it really necessary to add water and coolant separately, rather than mix them in right proportion beforehand? (Not to mention that they require to add coolant to the radiator before removing radiator cap?)
Also, what coolant would you recommend? "One-of-a-kind-secret-mixture-or-else-you-lose-your-warranty" from a dealership or something else?
Go to the top of the page
+Reply
montego
post Oct 12 2009, 11:33 AM
Post #2
Administrator
Group Icon
Group: Administrator
Status: Offline
Drives: XG's (2001&2002)
you can of course mix your water and anti-freeze before you add the mixture to the radiator (do not use more than 45% anti-freeze)
all anti-freeze is standerd and will mix with any old solution except the 'red' anti-freeze. if your car has the red already in the system then you must use red to top it up and it will not mix with other types
+Reply
U-96
post Oct 12 2009, 04:10 PM
Post #3
Member
Group: Members
Status: Offline
That's what I thought. Thanks!
+Reply
DSHornet
post Oct 13 2009, 01:45 AM
Post #4
Full Member
Group: Members
Status: Offline
Drives: 07 Tucson Limited, 01 Santa Fe GLX 4WD
QUOTE (montego @ Oct 12 2009, 11:33 AM) *
All anti-freeze is standard and will mix with any old solution except the 'red' anti-freeze. if your car has the red already in the system then you must use red to top it up and it will not mix with other types
MMM, I dunno about the 45% limit unless he lives in a warm climate, like the South or the Southeast where it rarely drops below -10 degF. In Alabama I have seen the temp get below zero Fahrenheit only two or three times, so the 45% mix would be fine for us, but not if I traveled north with it in m car, where I might see -15 degF overnight. The 50/50 mix is recommended for being prepared for any travel around the CONUS.
If he lives in New Hampshire, especially upstate (like Mt Washington, which is REALLY upstate!), he might want to make it 50% or 55%. The extra freeze protection may be needed there. If I remember the ratio table, ethylene glycol in a 50/50 mix will freeze at -34 deg F. I'm not sure about 55/45, but its freezing point is probably around -38 to -40 degF. A 55% mix may make the engine run a little warm since ethylene glycol doesn't conduct heat like pure water, so that change in the ratio shouldn't make a lot of difference, but I wouldn't go over 60% antifreeze.
Changing oil to 5W-20 for winter use might be a good idea, though. Here in the "Sunny South" I run 5W-30 Mobil 1 year round and have no problems.
+Reply
U-96
post Oct 19 2009, 07:39 AM
Post #5
Member
Group: Members
Status: Offline
Changed coolant yesterday. When I drained coolant, only approx half of the system capacity came out from the radiator plug - ~1 gallon instead of 7.4 qts. How do I drain the whole thing?
I did it twice (drained and filled, drove around, drained and filled again) to get at least 75% concentration of the fresh coolant. But I hope someone could educate me how to replace 100% in less time consuming manner.
There is another strange thing happens. When I drained the radiator for the first time, the recovery tank emptied as well. Second time, the recovery tank stayed filled. Anybody knows why is that and should I worry about it?
Thanks!
+Reply
hyscott
post Oct 19 2009, 11:02 PM
Post #6
Newbie
Group: Members
Status: Offline
Drives: 2004 Hyundai Santa Fe 2.7GLS
As long as there is no air bubble in the system, and everything stays cool, I wouldn't worry about it.
+Reply
U-96
post Oct 26 2009, 07:58 AM
Post #7
Member
Group: Members
Status: Offline
Ok, it seems to me the question how to change all the coolant (as opposed to only ~50% that one can drain from the radiator) is the best kept secret around here... I found this question being asked several times on the forum, with no intelligible answer.
How do I join that clandestine society of people who know this sacred ritual?
This post has been edited by U-96: Oct 26 2009, 07:59 AM
+Reply
  Advanced Search
0 Members:
Collapse
> Similar Topics
No New Posts Topic has attachmentsCoolant Temperature Sensor Location
Please Help!
2 santafesuv 46 19th November 2009 - 04:54 AM
Last post by: santafesuv
No New Posts Change Plastic Engine Cover On A 2001 To 2003 Cover
2 doggie71 38 17th November 2009 - 04:52 PM
Last post by: lovemysantafe
No New Posts Coolant Issues
Radiator
5 01 Blue Shark 67 5th November 2009 - 03:19 PM
Last post by: 01 Blue Shark
No New Posts Coolant Trouble
Head gasket? or Heater Core?
6 schellmis63 72 26th October 2009 - 05:53 PM
Last post by: montego
No New Posts Topic has attachmentsChange Entertainment Player
3 khy 109 14th October 2009 - 08:18 AM
Last post by: Robert B.
21st November 2009 - 05:02 AM
Privacy Statement
