 Hyundai-Forums.com > Hyundai Models > Sonata Forum > 4G (2006+) Sonata
> Paint Fading Problem
Arrone
post Sep 24 2009, 12:15 AM
Post #1
Member
Group: Members
Status: Offline
Drives: 2006 Hyundai Sonata
Ok, was applying Scratch X using a buffer and apparently kept it on one spot for too long (yes, big mistake...didn't know it could go through it that quick) and there's a faded spot on it now from it trying to blend everything in. That kind of line of small dots is apparently goo gone that my brother let on when he was trying to get these sap stains off, there's more streaks on other parts of teh hood too. The sap/goo gone stains was in North Carolina, and now I'm in San Diego. I don't have a job right now as I'm getting used to college, so what would be the cheap and effective way to solve these problems?
I read on the forums that I could use toothpaste as a primer for a touch up pen, would that work for either the goo gone stain or the faded spot?
(IMG:http://i55.photobucket.com/albums/g139/Arrone_MP/IMG00019-20090923-2200.jpg)
This post has been edited by Arrone: Sep 24 2009, 12:16 AM
Go to the top of the page
+Reply
MiamiLX
post Sep 24 2009, 12:35 AM
Post #2
Veteran
Group Icon
Group: Super Mod
Status: Offline
Drives: 2006 Sonata LX V6
I'm sorry but you said you were using Scratch X with a Buffer (IMG:style_emoticons/default/whistling.gif) (IMG:style_emoticons/default/00000732.gif)
And you were going to change the Color of the Dash if I remember correctly? That is not
fading paint, that is damage. I would not do any more Mods & leave the stock look, while you can.
All the toothpaste & Paint Pens in the world can not fix that, although I understand Crest is best! (IMG:style_emoticons/default/thumbsup.gif)
+Reply
Arrone
post Sep 24 2009, 12:46 AM
Post #3
Member
Group: Members
Status: Offline
Yeah I know, last time I listen to my friend about car maintenance . "Yeah, just get scratch x and buffer 'em out, SHOULD work..."
+Reply
PoMansAWD
post Sep 24 2009, 01:41 AM
Post #4
Senior
Group: Members
Status: Offline
Drives: 2008 Hyundai Santa Fe GLS AWD, 2008 Honda Odyssey LX babe magnet addition
Next time for tree sap, try WD40, silicone spray or mineral spirits and a clean rag. It will dissolve it right off w/out damaging the finish. A power buffer not kept in motion is a bad thing.
Joel
+Reply
Arrone
post Sep 24 2009, 04:17 AM
Post #5
Member
Group: Members
Status: Offline
QUOTE (MiamiLX @ Sep 24 2009, 01:35 AM) *
Why is that?
So it looks like I'd have to get my whole hood repainted? There's not really an easy fix?
This post has been edited by Arrone: Sep 24 2009, 04:56 AM
+Reply
jsinton
post Sep 24 2009, 08:18 AM
Post #6
Veteran
Group: Members
Status: Online
Drives: 1999 Elantra
No, of course not. You burned the paint. Either repaint it (hope the color matches) or live with it.
+Reply
thetyguy
post Sep 24 2009, 12:12 PM
Post #7
Member
Group: Members
Status: Offline
Ouch. Scratch X is decent for small touch ups when applied by hand, but I'd be reluctant to use a buffing machine in combination with that compound.
At any rate, the clear coat has been burned and it sounds like the base coat may even be damaged. With no clear coat, that section of the hood is going to be extremely vulnerable to oxidation. You'll want to frequently wax the area to prevent further damage. The touch-up pen will work for small nicks like rock chips, where a small section of paint has been removed, but it's impossible to lay down a smooth layer, so trying to repaint a section of the hood with that tool is not recommended. Really, the only solution is sanding, priming, and painting, which, if you don't want it to look even worse, should be done in a shop by an experienced hand using the right tools. Wet paint is a magnet for dust. Plus you'll want the texture, metal flake (assuming you have metallic paint), gloss, and color to match your fenders. And any areas with rock chips or other damage should be sanded flat before the primer is applied so that the final coat is smooth. That's a skill best left to a professional.
My recommendation while you're short on funds is to chock the incident up to a lesson learned, keep the damaged areas waxed, and if it really bothers you, squirrel away the funds needed for a professional finish down the road (not easy in college, I know).
Best of luck in your studies, and enjoy those college days.
-Ty
+Reply
Yiran Hu
post Sep 24 2009, 02:26 PM
Post #8
Full Member
Group: Members
Status: Offline
Drives: 2006 Hyundai Sonata 3.3 V6
Not sure if you want to try any more fixes... but you "could" sand and touch up just that spot with factory spray can of color and then clear over it... unfortunately you'd still have to compound and polish to get it "blended" with the surrounding paint. You might be able to post an ad on craigslist or something to see if some body shop person wouldn't mind doing a little touch up for you on the side. As long as you are not asking for perfection and they know what their doing, this actually can be done pretty quickly and at a decent enough price... It will look a lot better and there will at least be paint on the thing to prevent the burnt paint from disintegrating and causing rust...
+Reply
Arrone
post Sep 24 2009, 07:02 PM
Post #9
Member
Group: Members
Status: Offline
QUOTE (Yiran Hu @ Sep 24 2009, 03:26 PM) *
heheh, I think I've "blended" a bit too much the first time on my own ;)
And yeah thetyguy, that was my plan, just to save up money for a paint job. Like right after I noticed the mark, I started putting wax on it. Definitely a lesson learned, it may be a used car but I really like my Sonata.
+Reply
thetyguy
post Sep 25 2009, 03:03 PM
Post #10
Member
Group: Members
Status: Offline
Sounds like you've made a good decision. My first college car, a Toyota pickup, didn't even have paint in all areas after the factory metal flake dark gray paint started peeling. That thing was a serious eyesore for awhile, so I felt it requisite to keep it covered in mud from some 4X4 trail in the Utah mountains. Fun vehicle. For now, my practical side is making vehicle choices.
+Reply
  Advanced Search
0 Members:
Collapse
> Similar Topics
No New Posts Problem Internal Lighting Of Dash
2 jimpa 109 17th November 2009 - 08:26 AM
Last post by: DrO
No New Posts Paint.....cant Find It =(
i wanna find my color in a spray can...
9 Mini-Beast 119 10th November 2009 - 05:04 PM
Last post by: Mini-Beast
No New Posts Topic has attachmentsPainted My Calipers
front only .. for now
12 ItalianM87 421 29th October 2009 - 04:18 PM
Last post by: wjw
No New Posts Paint Code
0 Joser818 46 24th October 2009 - 08:10 PM
Last post by: Joser818
No New Posts Problem With The Stereo Sound System In The Getz
1 hycar 165 30th September 2009 - 04:49 AM
Last post by: gramin
21st November 2009 - 05:19 AM
Privacy Statement
