 Hyundai-Forums.com > Hyundai Models > Santa Fe Forum > 1G (2001-2006) Santa Fe
> Rear Differential & Transfer Case
ruthlessromeo
post Sep 9 2009, 08:14 AM
Post #1
Member
Group: Members
Status: Offline
Drives: 2006 Hyundai Sonata v6
Can't seem to find this so going to post a new topic. I plan on replacing the fluids in my wife's 2005 Santa Fe.
Transfer Case
I found these instructions on how to replace:
http://hyundaisantafemessageboard.yuku.com...ewtopic/id/2592
Anyone know what type of fluid is needed and how much of it? I Have seen API GL-5 but not sure if this is correct.
Also anyone know what size Hex bolt I need?
Rear Differential
Anyone have instructions on how to do this?
Anyone know what type of fluid is needed and how much of it? I Have seen SAE 80W90 gear oil but again not sure if this is correct.
Thanks,
Joe
Go to the top of the page
+Reply
jsinton
post Sep 9 2009, 08:36 AM
Post #2
Veteran
Group: Members
Status: Offline
Drives: 1999 Elantra
"Your Hyundai automatic transaxle is specially
designed to operate with HYUNDAI GENUINE
ATF SP III, DIAMOND ATF SP III, SK ATF SP
III or other brands approved by Hyundai Motor
Co., Damage caused by a nonspecified fluid is
not covered by your new vehicle limited warranty"
Transfer case and differential both specify. See owners manual under section 9:
API GL - 5 80w-90 gear oil.
+Reply
ruthlessromeo
post Sep 10 2009, 08:00 AM
Post #3
Member
Group: Members
Status: Offline
QUOTE (jsinton @ Sep 9 2009, 09:36 AM) *
Looks like ill pick the fluids up at the dealer
+Reply
PeterC
post Sep 10 2009, 07:13 PM
Post #4
Full Member
Group: Members
Status: Offline
Drives: 2006 Hyundai Tucson and 2007 Hyundai Accent (best half's car)
A thought?
On my Tucson, you can't get all the fluid out of the tranny without a LOT of weird methods being used. That, and the fact that my Hyundai dealer with take ANY dealer's coupons as long as not expired. So I got the Tranny seriver done for 94 bucks - you *may* wish to price out the cost of the fluid, and find out if you can remove it all? To me, the 30 bucks more it cost me was worth the lack of hassle combined with knowing it was complutely flushed...
HTH
+Reply
ruthlessromeo
post Sep 10 2009, 08:03 PM
Post #5
Member
Group: Members
Status: Offline
Seems like in Ohio they know how to treat customers but for me i say Stealership never again... After being charged 400 for a 60k which only consisted of coolant and tranny fluid flush they tell me its another 250 for the rear diff and 150 for the transcase. I then verified with 2 other dealers on this pricing, they confirmed. I couldnt believe a 60k only consisted of this even though the maintenance manual has so many other things that need to be done at 60k one of them being the timing belt. So with that said i refuse to pay them these prices to unscrew a couple bolts and use 50 bucks worth of fluid again.
This post has been edited by ruthlessromeo: Sep 14 2009, 07:22 AM
+Reply
jsinton
post Sep 10 2009, 08:09 PM
Post #6
Veteran
Group: Members
Status: Offline
QUOTE (ruthlessromeo @ Sep 10 2009, 09:03 PM) *
Seems like in Ohio they know how to treat customers but for me i say Stealership never again... After being charged 600 for a 60k which only consisted of coolant and tranny fluid flush they tell me its another 250 for the rear diff and 150 for the transcase. I then verified with 2 other dealers on this pricing, they confirmed. I couldnt believe a 60k only consisted of this even though the maintenance manual has so many other things that need to be done at 60k one of them being the timing belt. So with that said i refuse to pay them these prices to unscrew a couple bolts and use 50 bucks worth of fluid again.
Actually, it's plain old gear oil for the rear differential and transfer case. You buy it at Walmart in gallon jugs for $13, or $4 a quart. I think a gallon of gear oil should be enough. So yeah, it's a rip off.
+Reply
PoMansAWD
post Sep 18 2009, 07:16 PM
Post #7
Senior
Group: Members
Status: Offline
Drives: 2008 Hyundai Santa Fe GLS AWD, 2008 Honda Odyssey LX babe magnet addition
Joe, good find on the link for the transfer case & rear diff drain/fill! My 2008 specs 70w90 gear oil for both. I'm just glad to see it's just plain'ol hypoid gear oil for these boxes and no fancy super expensive dealer only stuff.
Joel
+Reply
ruthlessromeo
post Oct 24 2009, 08:29 PM
Post #8
Member
Group: Members
Status: Offline
Did them today...
Rear diff uses lil under 2 quarts and the transfer case around the same. It is a 10mm Socket (looks like a allen wrench in a socket) to take off the fill plug for the transfer case. Was easier then an oil change dont understand why dealers charge so much for such a simple thing to do. Cost 15 bucks worth of fluid much better then dishing out what the dealer chargers.
Looks like someone else posted some good pictures
http://www.hyundai-forums.com/index.php?showtopic=41105
This post has been edited by ruthlessromeo: Oct 24 2009, 08:33 PM
+Reply
PoMansAWD
post Oct 24 2009, 09:58 PM
Post #9
Senior
Group: Members
Status: Offline
QUOTE (ruthlessromeo @ Oct 24 2009, 09:29 PM) *
Did them today...
Maybe the 2006 and under are different. The 2007+ take just under a quart for the T-case and just under a quart for the rear diff. 0.84 and 0.95qts to be exact. It's ridiculously easy to drain/fill either. I just did it and posted the results. Hard to believe a dealer would charge 100's of dollars for that. I just noticed the 2006 and under spec 80w90 where the 2007+ spec 70w90. I went middle ground w/ easy to find 75w90. The differences between the 3 are negligible. A quality 75w90 will be fine for any model year SF.
Joel
This post has been edited by PoMansAWD: Oct 25 2009, 08:52 AM
+Reply
ruthlessromeo
post Oct 24 2009, 11:18 PM
Post #10
Member
Group: Members
Status: Offline
QUOTE (PoMansAWD @ Oct 24 2009, 10:58 PM) *
Maybe the 2006 and under are different, but the 2007 take just under a quart for the T-case and just under a quart for the rear diff. 0.84 and 0.95qts to be exact. It's ridiculously easy to drain/fill either. I just did it and posted the results. Hard to believe a dealer would charge 100's of dollars for that.
Joel
Ya good pics joel, saw the post today.. looks pretty much the same on the earlier models only little more fuild and a different weight (API GL - 5 80w-90 gear oil.)
+Reply
  Advanced Search
0 Members:
Collapse
> Similar Topics
No New Posts Differential Pin
4 beerken 126 18th November 2009 - 12:58 PM
Last post by: beerken
No New Posts Rear Driver's Running Light Not Working
3 doggie71 50 18th November 2009 - 01:13 AM
Last post by: doggie71
No New Posts Rearview Mirror Backup Camera And Homelink
3 SgrB2 91 17th November 2009 - 08:37 AM
Last post by: SgrB2
No New Posts Amplifed Vs Non-amplified
2005 Sonata and 2003 Santa Fe
0 jkamra2 23 15th November 2009 - 10:20 PM
Last post by: jkamra2
No New Posts Transfer Case Leak
1 tomcal 43 14th November 2009 - 09:17 AM
Last post by: PoMansAWD
21st November 2009 - 06:54 AM
Privacy Statement
