 Hyundai-Forums.com > Hyundai Models > Terracan Forum
> The Infamous Brake Switch (terracan And Others), Check engine lights turns on intermittently with loss of power
Robert B.
post Aug 18 2009, 08:36 AM
Post #1
Full Member
Group: Members
Status: Offline
Drives: 2004 Terracan 2.9 CDRi, 2008 Getz 1.6
Moderators, I suggest this post be pinned since its important technical information).
It all started about two months ago. My check engine light turned on breifly for a few seconds while driving normally (constant speed). The engine lost all power while light was on. Then, it all came back to normal. This happened about once a week till last week which happened two or three times daily.
Quite afraid suspecting some injection or pump failure (those are expensive to repair), I went to the local Hyundai dealer's garage and they plugged in the analyser. Error code #0229 (brake/accelerator switch error). They told me its a common error and very easy to fix. The brake switch has to be replaced, and they did. Also the error code then was cleared from the ECM.
The logics about this error code and behavior is as follows:
1) Braking and accelerating at the same time is NOT a normal driving behavior, so the ECM is programmed to detect such condition as an abnormal situation, then kills power to the engine in an attempt to protect vehicle and passengers from a possible accident.
2) The brake switch that is actuated by the brake pedal, has two sets of contacts. One set signals the brake light and the other set signals the ECM.
3) At some given point, the brake switch may issue a wrong signal (that the brake is being applied) when you are really accelerating (for example). Then, the ECM detects this abnormal condition and kills engine power and also signals there is something wrong, by turning on the check engine light.
4) Possible reasons for the faulty brake switch are: a) The actuator plunger (plastic) wears off enough (its in contact with the brake pedal frame bar) and it may short the contacts that signal the brake light without shorting the contacts that signal the ECM. (IMG:style_emoticons/default/cool.gif) The inner springs in the switch loose tension producing the condition explained in a), and finally, c) The contacts itself get some kind of contamination (inside the switch) producing the same conditions.
The part is cheap (US$10) and I was not charged for the labor. If fact, is quite easy to do by yourself, but you will still need to clear the error code from the ECM.
IMPORTANT: I was told by them that Hyundai replaced the part (new part number) which means there is an actual difference, probably fixing this error. They also told me this error applies to every crdi diesel vehicle from hyundai/kia, with auto or manual transmissions. Also, that sometimes, the error happens but the check engine light does not turn on.
About how old (miles/kms) for this to happen, it all depends on driving conditions, buy they told me they've fixed this in several terracans and starex vans between 80,000 and 100,000 kms).
I've been driving for a full week now and the check engine light has not turned on.
Se attached picture for details.
Attached File  TERRACAN_BRAKE_SWITCH.jpg ( 210.86K ) Number of downloads: 47
Robert B.
This post has been edited by Robert B.: Aug 18 2009, 08:47 AM
Go to the top of the page
+Reply
Juanita99
post Aug 20 2009, 02:30 AM
Post #2
Newbie
Group: Members
Status: Offline
Drives: car
QUOTE (Robert B. @ Aug 18 2009, 09:36 AM) *
Robert B.
Welcome to the site, thank you for supporting the site. It's people like you who read and try things yourself that make our lives a bit easier. Thank you.
meilleur taux credit immobilier simulation en ligne deFrance Simulation credit immobilier. crédit
immobilier de France. Selon un article des Echos du 5 mai 2009, « le dernier spécialiste du
crédit
meilleur
taux credit immobilier simulation en ligne de France
+Reply
doori
post Aug 20 2009, 06:13 AM
Post #3
Newbie
Group: Members
Status: Offline
Drives: terrican
Thanks Robert B. for the info and pic
(IMG:style_emoticons/default/liebe011.gif)
cheer , Doori
+Reply
  Advanced Search
0 Members:
Collapse
> Similar Topics
No New Posts Brake Light Switch Replacement Help (brake Pedal)
0 h00ligan 12 Yesterday, 01:48 PM
Last post by: h00ligan
No New Posts Terracan Ventilation
Funny Smell Update
3 GidBoy 74 17th November 2009 - 12:11 PM
Last post by: madtrucker
No New Posts Brake Lamp Out At 27k
5 disaster 123 15th November 2009 - 08:47 AM
Last post by: ddix1026
No new Brake Light Switch Recall
How long does it take?
27 tjnamtiw 921 14th November 2009 - 04:58 PM
Last post by: ohsevenwhiteSE
No New Posts The Maddest Hyundai Of Planet
Video without driver jump another car
1 plokami 545 12th November 2009 - 02:43 PM
Last post by: JohnIrvine1
21st November 2009 - 03:38 AM
Privacy Statement
