 Hyundai-Forums.com > Hyundai Models > Accent Forum > 1G (1995-1999) Accent
> Water Pump Help 1.5 Dohc Asap
Stimmel
post Jul 3 2009, 07:52 PM
Post #1
Newbie
Group: Members
Status: Offline
Drives: 1996 Accent GT
I am doing or at least trying to do the water pump on my 1996 hyundai accent gt dohc 5 speed car, do I have to removed the crank pulley to do this?
and can anyone give me a good write up on this or a link or somehting i need to get this done asap
Thanks
Go to the top of the page
+Reply
WOT
post Jul 3 2009, 09:50 PM
Post #2
Member
Group: Members
Status: Offline
Drives: 1998 Accent; 2007 Veracruz
I'd highly recommend purchasing the "Hyundai Excel & Accent" Haynes Repair Manual for 1986 thru 1998 models (#43015). I own a '98 Accent and have changed the water pump on that following the instructions provided in the Haynes book, in conjunction with the factory service manuals. On my '98, I did it at the same time as the timing belt. If memory serves me correctly, the timing belt tensioner has to be removed in order to access the water pump. The Haynes manual does not indicate that there is any difference in procedure between years, so I'm assuming that the tensioner/idler is in the way on your '96 as well. In that case, you'll most likely need to remove the crankshaft pulley and the timing belt cover so that you can access everything else.
Look at the shop manual information provided on the "hmaservice.com" site. For yours, it looks like it can be found under: ACCENT(X3) > 1996 > G 1.5 DOHC > Engine Mechanical System > Cooling System > Engine Coolant Pump > DISASSEMBLY. ...That also indicates that the timing belt idler is in the way.
When you replace the pump, don't forget to replace the O-ring on the coolant pipe (assuming yours has the coolant pipe coming out of the back), along with the water pump gasket. For me, the O-ring was a dealership item.
Hope that helps.
+Reply
montego
post Jul 4 2009, 08:15 AM
Post #3
Administrator
Group Icon
Group: Administrator
Status: Offline
Drives: XG's (2001&2002)
its rather pointless to do all this work changing the water pump unless you change the timing belt at the same time unless the belt has been changed very recently, you will need to remove the crankshaft pulley to change the belt but not so if you are just going to change the pump
+Reply
  Advanced Search
0 Members:
Collapse
> Similar Topics
No New Posts Help Please...noisy Lifters
11 beware 154 Yesterday, 10:06 PM
Last post by: PoMansAWD
No New Posts Water Inside Cabin
5 cjs 545 Yesterday, 09:54 PM
No New Posts Help P1124
Accent threw a P1124 what could need fixed?
6 Crad008 88 18th November 2009 - 09:32 PM
Last post by: rsquared
No New Posts Help Needed In Removing Front Instuments Pannel. (atoz/s)
help needed in removing front instuments pannel. (atoz/s)
2 yuval lahav 119 18th November 2009 - 01:41 PM
Last post by: SPOOLER1612
No New Posts Help Fuse Probleme
0 don_gizmos 44 6th November 2009 - 03:42 PM
Last post by: don_gizmos
21st November 2009 - 01:45 AM
Privacy Statement
