 Hyundai-Forums.com > Hyundai Models > Veracruz Forum
> Change Head Light, How to change passenger side headlight
Notsuitable
post Jun 18 2009, 09:36 PM
Post #1
Newbie
Group: Members
Status: Offline
Drives: 08 Veracruz GL
HELP! - Has anyone had to change the passenger side low beam headlight? Looking for pointers and tips as it seems to be in a very tight confined space and I can not get my hand on the headlight bulb cover to turn it clockwise, ect.
The driver side is exposed and appears simple, however the passenger side looks near impossible.
While I'm asking does anyone know what buld it takes for the low beam?
This post has been edited by Notsuitable: Jun 19 2009, 09:18 AM
Go to the top of the page
+Reply
Notsuitable
post Jun 19 2009, 09:17 AM
Post #2
Newbie
Group: Members
Status: Offline
Okay, found this in a later forum, think I will head to the dealer.
Quote
The reason you can't get at the right hand side to replace the bulb is that Hyundai placed the ABS electronic control module right behind the headlamp assembly unit. There are only three bolts that hold the ABS mounting plate to the car body - remove those three bolts, and you can lift out the entire ABS control unit. Don't remove the ABS module from the plastic mounting plate - just remove the mounting plate, together with the ABS unit. You will need a ratchet wrench with an extension shaft to reach the three bolts.
If you need to, you can also unplug the cable connectors to the ABS unit. Reconnect them after you re-install the ABS unit. If you do this, then disconnect the battery and reconnect it when you are done, or else your engine trouble light will come on.
You will also have to remove the upper portion of the windshield washer resevoir filling neck - this is accomplished by removing a single bolt and then pulling the neck assembly away from the body of the windshield washer resevoir.
With the ABS module and windshield washer resevoir neck removed, you can access the rear of the right headlight assembly.
This post has been edited by Notsuitable: Jun 20 2009, 01:09 PM
+Reply
Notsuitable
post Jun 20 2009, 01:10 PM
Post #3
Newbie
Group: Members
Status: Offline
QUOTE (Notsuitable @ Jun 19 2009, 10:17 AM) *
Quote
Just back from the dealer and watched the headlight get replaced ($18.00 labour).
They removed the top two bolts for the lamp assembly and then removed a third bolt from the back of the assembly. The top bolts are readily seen when you look at the top of the assembly where the light comes in contact with the hood. The third bolt if you look at the driver-side assembly will assist you in locating it. It took the dealer about 15 min to change the bulb. Did not touch the ABS Module.
This post has been edited by Notsuitable: Jun 20 2009, 01:12 PM
+Reply
  Advanced Search
0 Members:
Collapse
> Similar Topics
No New Posts Lighting For Homelink !
why is the mirror not lit
8 TLSRULZ 236 20th November 2009 - 07:31 PM
Last post by: congo
No New Posts Change Plastic Engine Cover On A 2001 To 2003 Cover
2 doggie71 39 17th November 2009 - 04:52 PM
Last post by: lovemysantafe
No New Posts Headlight Relay Access
0 carpcrew 24 14th November 2009 - 09:21 AM
Last post by: carpcrew
No New Posts Headlight Removal - Need Help With Reinstall
0 whec716 72 8th November 2009 - 06:57 PM
Last post by: whec716
No New Posts Head Lights Don't Work
1 Dario 345 7th November 2009 - 12:39 AM
Last post by: MDK87
22nd November 2009 - 12:45 AM
Privacy Statement
