 Hyundai-Forums.com > Hyundai Models > Terracan Forum
> Low Idle Speed At Start Up
porky
post Dec 18 2008, 09:46 AM
Drives: terracan 2.9crtd 2005 manual
Hi all, I am experiencing an intermitant problem on my 2005 crd manual. It will start and instead of idling at approx 800 rpm it only gets to about 500rpm. If you swich off and restart it then will perform normally. Its been back to the dealer for a diagnostic check but it showed no fault codes. Its been ok since the trip to the dealer about two weeks ago, but has now flared up again. Its due back in the dealer on monday, but has anyone else experienced this, and if so what was the fix? The dealer will probably say no fault codes again and do nothing, so anyone got any pointers? cheers (IMG:style_emoticons/default/unsure.gif) When driving the car performs normally. When it is idling at the lower level, the throttle shows no response.
This post has been edited by porky: Dec 18 2008, 09:47 AM
montego
post Dec 18 2008, 12:53 PM
Administrator
Group: Administrator
Drives: XG's (2001&2002)
possible coolant temp. sensor but your dealer should be able to pin point this, have you left the vehicle with the dealer overnight so that they can experience the fault first hand in the morning when its cold?
porky
post Dec 19 2008, 03:56 AM
Thanks montego. The problem isnt specifically when the engine is cold. It did it 5 times on wednesday (throuhout the day) but has been fine since, including this morning, when it was very cold. I am a bit worried as i have heard about problems with the fuel pumps and hope it isnt the start of something serious. The car drives normally and starts normally for most of the time, and no warning lights have come on, so i am hoping its not anything to do with the fuel pump. The coolant temp reading seems fine (it stays at just under half on the gauge once warm). Anybody got any other ideas? (IMG:style_emoticons/default/sad.gif)
Hyundaiownersclu...
post Dec 19 2008, 01:06 PM
Drives: Tucson
QUOTE (porky @ Dec 19 2008, 08:56 AM) *
Your dealer should take some live data readings and send them to Hyundai Technical. Its not just a case of code reading these days.
porky
post Dec 19 2008, 02:04 PM
Thanks HOC, I will ask them to do that if they cant find any fault. (IMG:style_emoticons/default/thumbsup.gif) Would you have any idea what it could be?
Hyundaiownersclu...
post Dec 19 2008, 05:06 PM
Drives: Tucson
QUOTE (porky @ Dec 19 2008, 07:04 PM) *
Unfortunately not. Brake switch/Mass Air Flow/Fuel Pump,even an injector but its just a guess
porky
post Dec 20 2008, 08:02 AM
Thanks anyway! (IMG:style_emoticons/default/thumbsup.gif)
porky
post Dec 22 2008, 07:15 AM
Well, been back to dealer today and they still cant find anything wrong and cant give any explanation. No fault codes, checked fuel filter but everything fine. So i am completely stumped! They said they will contact the dealer network to see if there has been anything similar reported. Fingers crossed!!
BJL
post Dec 30 2008, 05:22 PM
Drives: Terracan Highlander 2.9 Crdi Manual
I had an intermitent idle problem with mine as well (2005 CRDi manual), only thing was that it would go from 800rpm up to 1000 rpm for no apparent reason. The problem then became constant, but if you just touched to brake pedal so the brake lights came on the idle would drop back down to 800rpm.
The final solution was to replace a faulty knock sensor. Once again no fault codes showed up, but one other vehicle here in Oz had had a similar problem and it was found on the Hyundai dealers forum site.
My knock sensor may have failed in full advance and yours might have failed in fully retarded (just a guess).
This post has been edited by BJL: Dec 30 2008, 05:23 PM
porky
post Jan 1 2009, 07:41 AM
Thanks BJL, I will mention that to dealer if it plays p again. It is fine at the moment (IMG:style_emoticons/default/57.gif) Happy New Year !
Hyundaiownersclu...
post Jan 2 2009, 12:48 PM
Post #11
Drives: Tucson
QUOTE (BJL @ Dec 30 2008, 10:22 PM) *
I had one like yours aswell but not dropping revs like porky's
porky
post Feb 3 2009, 05:05 AM
Post #12
Update: the tcan has not done it again since last post. dealer found nothing wrong/no fault codes. (IMG:style_emoticons/default/smile.gif)
Hobbycar
post Feb 12 2009, 05:57 PM
Post #13
Drives: 2004 Terracan 2.5 T-Diesel
Porky, are you near Cardigan? I have some friends near there whom I have not seen since '97, they farm sheep. Jeff, in Costa Rica. Cheers.
porky
post Feb 13 2009, 11:14 AM
Post #14
Sorry jeff, i am a fair way from cardigan, but know plenty of sheep farmers (IMG:style_emoticons/default/whistling.gif)
Hobbycar
post Feb 13 2009, 02:42 PM
Post #15
Hey porky, you may know these people because they have won contests for their sheep, at things like spring fairs etc., I believe. Their first names are Eirwyn and Bessie. jeff.island@gmail.com
I met them when I drove tour bus in the Canadian Rockies in 1996 and visited them at their home in the spring of 1997. I found your area to be beautiful and would enjoy traveling there again. Maybe one day........
Cheers, Jeff.
porky
post Apr 27 2009, 09:36 AM
Post #16
Well, 5 months after the original problem, my local dealer has finally been able to diagnose a dodgy fuel pump (IMG:style_emoticons/default/mad.gif) after the problem recently flared up again. It appears that it was not holding pressure (so the fitter tells me). It is booked in in a fortnight for a replacement pump. Am i right in assuming that the whole fuel system needs replacing/flushing? Any help /advice would be great.
BJL
post Apr 27 2009, 07:04 PM
Post #17
There was a survey done by the Terracan forum in Oz and out of 49 respondants 5 had suffered a pump failure. There seems no real trend to the failure other than they may occur a short time after the fuel filter is replaced if the fuel system is not primed properly and the pump operates dry for a short period of time.
I think all fuel pump failures have also required the entire fuel system to be replace due to metal from the failing pump going through the injectors and fuel lines.
You can check this subject on the Oz forum at
http://forum.australia4wd.com/index.php?sh...mp;#entry116358
porky
post Apr 28 2009, 02:11 AM
Post #18
Thanks BJL. I have seen the info in oz and find it a great site. However, i am beginning to think that my problems are not connected to the fuel pump. The car drives perfectly, with no loss of power, or warning lights, the only time i have trouble is on start up. This is very sporadic and has no relationship to temp or fuel levels etc. I am no mechanic, but if the fuel pump was dodgy wouldnt i be experiencing probs all the time, and cetainly when driving? I think it may be a sensor/electrical problem. The dealer tested the fuel system after it failed to start in their workshop and i was told the fuel system was losing pressure. What would cause this? Is it only the fuel pump? They did not mention any fault codes, so are they just guessing? Thanks for any help anyone can give.
porky
post Apr 30 2009, 01:31 PM
Post #19
The plot thickens. The 'can failed to start again today, but this time the glow plug indicator did not illuminate!!! Left it for 5 minutes and the car started perfectly! (IMG:style_emoticons/default/unsure.gif) This is looking more and more like an electrical gremlin to me. The trouble is unless the fault shows up in dealer they cant diagnose any faults! (IMG:style_emoticons/default/rant2.gif) I would be grateful for any help!! (IMG:style_emoticons/default/57.gif)
porky
post May 14 2009, 12:08 PM
Post #20
Update! Had the 'can back from dealers today. The problem was a faulty rail pressure sensor. This involved changing the whole common rail and fuel pipes. It eventually showed up as a fault code. I hope this helps anyone with a similar problem! Its great to have the beast back after 4 days with a 3 door suzuki swift (IMG:style_emoticons/default/wacko.gif) Thanks to everyone who helped (IMG:style_emoticons/default/thumbsup.gif)
No New Posts Starting Problem
1 Skuggi 13 Yesterday, 05:59 PM
Last post by: montego
No new Topic has attachmentsUpshift Speeds...
24 UniR 1,181 Yesterday, 12:40 AM
Last post by: Volfy
No New Posts Atoz Changing Alternator Belt
1 ANDKAT 54 18th November 2009 - 01:27 PM
Last post by: SPOOLER1612
No new Lowering Springs
45 Meakame 592 17th November 2009 - 11:06 AM
Last post by: JohnIrvine1
No New Posts Atoz -failed Door Handle
2 gerryh 583 16th November 2009 - 01:37 AM
Last post by: plumer
22nd November 2009 - 01:04 AM
