Dear squid,
Deaf in one ear and still hear the noise? Get a friend and take them for a ride. Friend in right front seat, windows down. Try varying the speed to identify if the noise is consistent at one speed, and also note the rpm. Now, can you make the engine repeat the noise in a lower gear but at the same rpm??? If yes, the noise is from your engine. If no or the rpm where the noise occurs has changed, it is not the engine but more likely the transmission. If the friend says you are nuts he can't hear a thing...then the dealer is right.
Two things you can try: An quality engine oil flush can clean out the galleries and the tiny...I mean tiny holes in your hydraulic valve adjusters. Even running syhnthetic oil in your engine can still cause clogging over time.
Second, use an engine 'quiet' product like STP Oil Treatment or Bardahl's No Smoke to quiet any remaining noise.
Byron
