 Hyundai-Forums.com > Hyundai Models > Accent Forum > 2G (2000-2005) Accent
> Help! After Every Fill-up Cel Code P0304, 2004 Accent - auto. - 100K miles
273HYPO
post Aug 31 2008, 10:21 AM
Post #1
Member
Group: Members
Status: Offline
Drives: 2004 Accent GLS
Ok fellas, some you have seen my posts dealing with my CEL for code P0304. I thought I had it solved but now it comes on after every fuel fill-up. Its happened at least 5 times or more. I know what the code means (ign. misfire #4 cyl.).
I read and checked what affects the code but this one has me baffled. I thought at first it is the evap. canister but the car takes a fuel fill-up without any trouble and it is not hard to pump it all in and does not give me the code. If I put a bottle of STP gas treatment in the tank it clears the code after about 40 miles drivieng but it doesn't explain why it sets off the CEL on every fill-up. I also thought I may have sediment in the tank and the fill-up is stirring it up but I have filled her up and various capacities. Also, several weeks ago I got the CEL code P0441 for the purge control valve. I replaced it, cleared the CEL and it never came back on. Fuel filter has never been replaced because it is built into the fuel pump assembly.
Overall drinvability and MPG's are not effect. Any thoughts fellas....
Go to the top of the page
+Reply
273HYPO
post Sep 5 2008, 08:16 PM
Post #2
Member
Group: Members
Status: Offline
Anyone wanna try and guess? CEL goes out around 2/3 of a tank of fuel.
+Reply
LilBean
post Sep 6 2008, 10:36 AM
Post #3
Expert
Group: Members
Status: Offline
Drives: 2010 Nordschleife Gray Genesis Coupe 3.8 Track
The fuel filter IS replaceable, even though it is in the tank. It's not "built into" the fuel pump, but you do have to do some disassembly to get to it.
It sounds as if you may have bad gas or sediment. I'd change the filter and maybe start using a different gas station.
+Reply
273HYPO
post Sep 6 2008, 06:27 PM
Post #4
Member
Group: Members
Status: Offline
I've ruled out the bad gas since my wife uses different gas stations and it has happened several times. And I would think that the CEL would stay on and not go off if the fuel filter is clogged. When the tropical storm HANNA settles down I'll look at the fuel filter for a replacement. Thx...Anyone else?
+Reply
congo_90
post Sep 9 2008, 07:12 PM
Post #5
Newbie
Group: Members
Status: Offline
Drives: 2000 Accent GS
i may not be 100% mechanical minded but if its saying "ignition mis-fire" have you checked your distributor, plugs and points? sounds kinda simple but it could just be the problem.. Does this fault affect driving? also, How did you first discover it? Last suggestion is a fuse has blown on the fuel delivery circruit / Bad ECU
+Reply
e30jean
post Feb 28 2009, 06:44 PM
Post #6
Newbie
Group: Members
Status: Offline
Drives: 04 accent
Same problem here. I already put in new plugs, and coils and it didn't make a difference. Today I replaced the ignition wires with new Bosch set, and the same error code came back on.
I wouldn't think it would be a fuel filter, since it's always the same code, misfire on 4th cyl.
Any ideas???
+Reply
ncoic
post Mar 31 2009, 12:36 PM
Post #7
Newbie
Group: Members
Status: Offline
Drives: 2000 sonata
since you already did plugs/wires and coil the next thing I would do is unplug the wire to the injector and see if the engine starts to stumble. If it doesn't you have a bad/clogged injector.
+Reply
strtbobber
post Jul 14 2009, 01:12 AM
Post #8
Newbie
Group: Members
Status: Offline
Drives: 2004 Hyundai Accent GS
Yup, my wife's '04 Accent sputters after each fill too. And we also have the p0304 "misfire on cyl #4" code. Replaced all ignition wires, plugs, etc. What to do????
This post has been edited by strtbobber: Jul 14 2009, 01:13 AM
+Reply
e30jean
post Jul 14 2009, 01:44 AM
Post #9
Newbie
Group: Members
Status: Offline
Drives: 04 accent
QUOTE (ncoic @ Mar 31 2009, 01:36 PM) *
Replaced injectors, checked compression and still doing the same thing.
+Reply
e30jean
post Nov 3 2009, 12:41 AM
Post #10
Newbie
Group: Members
Status: Offline
Drives: 04 accent
Anyone?
+Reply
64bb
post Nov 3 2009, 11:17 AM
Post #11
Newbie
Group: Members
Status: Offline
Drives: 2004 accent
ok, my two cents worth. my 2004 accent with 82K miles is doing exactly what yours is doing. it has been going on for a year and it is killing me. i also had a 0304 code and an 0441 code. the dealer said repalce purge valve; i did; the 0441 code is gone. however. everytime i fill it up, the cel flashes about 25 times and then stays on and i get an 0304 code. the plugs and wires are new hyundai parts. the spark from #4 is very strong, just like the other three. the #4 fuel injector clicks regularly and well with a mechanic stethoscope, just like the other three. the cel light frequently goes out after about 1/3 tank is gone, after sitting overnight.
here's my theory: this all started when i began getting gas at a station that used those accordion type collars on the pump nozzle. i think that those pumps really push in the fuel under extra pressure, and that my canister cannot handle the load. therefore, two weeks ago, i started going back to my old station, where there is only a loose splash guard on the pump nozzle. lo and behold, yesterday morning, after the second fillup, the cel flashed 25 times, but then stayed off, whereas for a year it always stayed on. this is the first and only time in a year that i did not get the cel staying on after a fuel fillup and after the 25 flashes. i do not know if this is a cure, but i think i am on the right track.
therefore, i am having a friend try to get the entire canister assembly off of a junker, with all hoses and with the white plastic attached electric control module. i will switch the used one with mine [10 minute job] to see if there is any improvement. in any case, things did get noticeably better for me when i went back to the old style splash guard fuel pump.
final thought: is there any pattern here with users of gasohol? my state of wisconsin is a gasohol state. perhaps all people with this problem are gasohol state people.
+Reply
  Advanced Search
0 Members:
Collapse
> Similar Topics
No New Posts Code Name Bh
Spy
3 Brazzel 439 18th November 2009 - 12:18 PM
Last post by: JohnIrvine1
No New Posts Topic has attachmentsAftermarket Mud Flaps
10 SantaFaer 345 14th November 2009 - 01:56 AM
Last post by: david-paul-1
No New Posts Aftermarket Cd Changer
install pioneer cd changer in 2009 sonata
2 cindybert 94 6th November 2009 - 06:02 PM
Last post by: cindybert
No New Posts Aftermarket Replacement Terminal
positive battery terminal clamp/tang w/stud
2 Richie03 322 27th October 2009 - 12:28 AM
Last post by: forx123
No New Posts Aftermarket Radio Will Not Fit 07 Elantra
Radio trim kits and Aftermarket options
2 tobadogs 206 10th October 2009 - 02:35 PM
Last post by: zuluzkiller
20th November 2009 - 08:11 PM
Privacy Statement
