 Hyundai-Forums.com > Hyundai Models > i30 Forum
4 Pages V  < 1 2 3 4 >
> Unusual Problem With I30 Crdi, Won't rev passed 3000rpm
Tony Marriott
post Apr 13 2008, 11:15 PM
Post #21
Newbie
Group: Members
Status: Offline
Drives: 2007 Hyundai i30 CRDi
I must be the 2nd of the 3 owners in Australia to have exactly the same problem.
Has occurred 5 times since I picked up the car in February.
At the 1000km service the dealer said next time it happens drive the car straight to the service centre and leave the engine running.
Service is only open Monday to Friday 8AM to 5pm, and the problem has not occurred since at a convienent time when I dont have to be at work.
Go to the top of the page
+Reply
tjaliwalpa
post Apr 13 2008, 11:37 PM
Post #22
Senior
Group: Members
Status: Offline
Drives: 08 i30 CRDi 1.6 Manual / 09 Santa Fe CRDi 2.2 Auto
Tony,
I too want it to occur when it is convenient to drive in and have the dealer look at the issue, but so far it has only occured after hours or on a weekend. I have 2 weeks holidays at the moment and am hoping it occurs when I can drive it to the dealer.
Bob
+Reply
buddyforu
post Apr 13 2008, 11:47 PM
Post #23
Member
Group: Members
Status: Offline
Drives: 2007 Hyundai i30 SR 2.0
If the car's faulty, it rediculous for the dealer to ask to take it to them whilst the fault is occuring. Just take it to them, and say FIX IT. The fault should be recorded in the ECU anyways.
+Reply
tjaliwalpa
post Apr 14 2008, 12:00 AM
Post #24
Senior
Group: Members
Status: Offline
buddyforu and others
If you read back in this thread you will see that the dealer I have is serious about getting the issue sorted as I believe Hyundai are. I take your point about taking it in and having them fix the issue, but it is not that easy as the problem rarely occurs (3 times in 5500k for me).
Apparently no info is stored about the problem in the ECU. I can believe this as no ECU or engine malfunction lights come on when the problem occurs.
I have heard that some ECUs in some makes of cars won't let you over-rev an engine when not moving. For example, the ECU in a Falcon X6 belonging to a friend will not rev over 3000rpm unless the transmission is operating. I checked this out on the i30 and engine revs over 3000rpm without an issueso that discounts some sort of limiter coming into play.
As I find new infoout I shall post further reports. I am hoping others with issues will do likewise.
Bob
+Reply
Lakes
post Apr 14 2008, 05:27 AM
Post #25
Senior
Group: Members
Status: Offline
Drives: 06 Sonarta 2.4,04 Falcon V8 Ute, 08 i30 CRDi poverty pack manuel
QUOTE(tjaliwalpa @ Apr 14 2008, 12:00 AM)
Bob
[right][snapback]152309[/snapback][/right]
Hi Bob & Tony,
Sorry you two have had this issue, with Diesels they operate from fuel being injected into the combustion chamber to be ignited by compression, the more fuel that is feed in the more HP & TQ they make and the faster they go, they do not use a butterfly to control the amount of air into the motor to control engine speed like a petrol motor uses. this is why you get a slight throttle lag with a diesel, so this problem is a fuel delivery problem. i don't think driving straight to the deler as it happens is going to work if it only happens once in a while. what i think is they probably should change the ECU for a new unit and then see if it happens again. But asa i said it is just what i think, does not mean i'm right, just useing common sense here.
John
+Reply
tjaliwalpa
post Apr 14 2008, 05:18 PM
Post #26
Senior
Group: Members
Status: Offline
Good comment John.
I have been thinking along similar lines. Dealer says that Hyundai are looking more at the sensors and valves that control the fuel delivery rather than the ECU itself. My thought is that eventually they will need to begin the process of elimination.
The main reason I will take my i30 if I am within cooee of the dealer when the problem occurs is to enable the deaer to directly put pressure on Hyundai to do something about it. I've already emailed them the link to the Youtube video.
Strange as it may seem, I am not anxious about the problem, just slightly annoyed.
Bob
+Reply
Lakes
post Apr 15 2008, 02:48 AM
Post #27
Senior
Group: Members
Status: Offline
Bob, seems strange the ECU does not have data logging so the dealer's tech can plug in a PC to check, but if they don't have it they could hook one up to find your problem, it's not hard you just hook up to the sensors just have to make sure the type sensors they use work with the data Logger then you need to know how to read what it shows you, but this is how they could find it. some cars and bikes with EFI on petol use fuel cut out to limit revs others use ignition cut out, diesels could only use the fuel cut out so probably something to do with that or even if you have traction control could be something with that.
good luck
John
+Reply
tjaliwalpa
post Apr 15 2008, 03:48 AM
Post #28
Senior
Group: Members
Status: Offline
John,
The ECU does have data logging. However, the problem is not registering in the ECU. If it were, then the techs would be looking there for the problem and therefore the solution.
You mentioned the ESP. I also thought of that very early on. The ESP can be turned off and I went straight to that to see if it had an effect, but it did not alter the situation.
I stress again, the problem can not be duplicated (3 times for me in over 5000k over 5 weeks). When I think, hey, I did this and it occured, then I try duplicating the situation but the problem does not occur.
Strange, but interesting.
Bob
+Reply
Lakes
post Apr 15 2008, 05:04 AM
Post #29
Senior
Group: Members
Status: Offline
Bob,
Does it just occure @ 3,000 rev when it won't rev past 3,000?
Bob with true data logging the system logs the data and you can play it back as it happened, you would be able to see what happened to the fuel curve. there are data loggers you can hook up and program to log all the info so you can play back on a pc later. i have one myself but have not used it with a diesel. i'm sure they will find problem if you keep at them.
John
+Reply
tjaliwalpa
post Apr 15 2008, 05:15 AM
Post #30
Senior
Group: Members
Status: Offline
John,
It is always at the same revs (a fractionunder 3000 rpm. It pulls ok to that rev level and continues to have good fuel economy.
It can be overcome by stwitching off the ignitionand restarting the vehicle.
A data logger would need to be connected for weeks to log the problem. It was just under 5 weeks between the 2nd occurence and the 3rd. That would be just over 4000k of travel between the 2 events. And as I said, no error light has appeared on the dash coming from the ECU at any stage. If a data logger records ECU events, would it record this particular event?
Bob
+Reply
Lakes
post Apr 15 2008, 06:03 AM
Post #31
Senior
Group: Members
Status: Offline
You are right Bob, there is a limit to how long you can record, i'm trying to think what rev TQ curve end's at but it is just before 3,000 if i remember right, i think TQ is from 1,900 to 2,???, i can't see how that could have anything to do with it but it's still interesting to think about.
John
+Reply
tjaliwalpa
post Apr 15 2008, 06:11 AM
Post #32
Senior
Group: Members
Status: Offline
Ya John,
I thought of that as well, but it is 2750rpm, below the rpm that is reached when the issue is present.
Bob
+Reply
Tony Marriott
post Apr 15 2008, 06:07 PM
Post #33
Newbie
Group: Members
Status: Offline
Happened again. Car was cold. Air 20deg C. Started driving the revs topped out in 1st 2nd and 3rd at 2900RPM.
Still felt like the power up to this rev limit was good, but I do think the power was slightly less than normal.
Restarted and problem was gone.
+Reply
tjaliwalpa
post Apr 16 2008, 02:42 AM
Post #34
Senior
Group: Members
Status: Offline
Tony,
Me thinks there is some tiny little component playing up. Switch it off, it resets itself and away it goes.
Hasn't happened to me again. Well, I should say it hasn't happened to OURI30, although I never rev out these days. What I need is a variable vein turbo boosting my direct injection. Can I say that on here without being sensored?
Bob
This post has been edited by tjaliwalpa: Apr 16 2008, 02:46 AM
+Reply
Lakes
post Apr 16 2008, 05:26 AM
Post #35
Senior
Group: Members
Status: Offline
Just wondering if one of those power tuners would help, they plug in and change the fuel map , but do not change factory limits on revs or turbo boost they just add fuel or subtract fuel, and they have tuning options, price sounds very resonable. i have e mailed a few times and they reply with any info you ask. they also unplug and all factory settings go back to stock. i know these systems are easy to install and remove, just like plugging in hardware to a pc.
might help you guy's, but still think you should keep at Hyundai to solve the problem.
i'm interested in one of these units but not straight away. would like to do a few k's and have a few services b4 doing anything. but i'm a motor man as i have said b4, also like driving.
John
+Reply
tjaliwalpa
post Apr 16 2008, 05:56 AM
Post #36
Senior
Group: Members
Status: Offline
John,
Are you talking about the DPChip? I have looked at them as an option further down the track. I would want the issue sorted before venturing down that path.
Bob
+Reply
Lakes
post Apr 16 2008, 06:01 AM
Post #37
Senior
Group: Members
Status: Offline
Bob i'll look up the link and post it, it is not a chip it's a direct plug in unit that uses same plug fitting as stock ECU, i've known other people that are friends who have diesel cars that have used and still use them with great results, one has a VW TDI
John
+Reply
Lakes
post Apr 16 2008, 06:08 AM
Post #38
Senior
Group: Members
Status: Offline
Bob here is the link
http://dieseltuner.com.au/
+Reply
tjaliwalpa
post Apr 16 2008, 06:29 AM
Post #39
Senior
Group: Members
Status: Offline
John,
While the product I am referring to is called the DPChip, it is a unit that plugs in in the same way, between the ECU and the engine.
The web link is http://www.dpchip.com.au
Bob
This post has been edited by tjaliwalpa: Apr 17 2008, 01:43 AM
+Reply
Lakes
post Apr 16 2008, 10:50 PM
Post #40
Senior
Group: Members
Status: Offline
QUOTE(tjaliwalpa @ Apr 16 2008, 06:29 AM)
John,
The web link is www.dpchip.com.au
Bob
[right][snapback]153149[/snapback][/right]
Bob saw that one two, there are a lot of these units around, just i have been e mailing with a guy from out here that sell's this unit i posted and he seems to be very helpful and honest, also i think the price of $990 incl GST and shipping australia wide is very reasonable, that is if it works, i know people that have used simialer gizmo's on Diesels that does same thing and they got really good power and Torque gains, this guy said these units are adjustable for fine tuning and are set to get there gains at very low revs.
John
+Reply
  Advanced Search
0 Members:
Collapse
> Similar Topics
No New Posts Problem Internal Lighting Of Dash
2 jimpa 109 17th November 2009 - 08:26 AM
Last post by: DrO
No New Posts I30 Alloys
0 rdz4 77 11th November 2009 - 09:50 AM
Last post by: rdz4
No New Posts Topic has attachmentsI30 Tow Bar
A coupla complaints...
18 dazzling_darryl 1,373 10th November 2009 - 05:25 AM
Last post by: marty62
No New Posts I30 Delivery
1 ghosty123 192 1st November 2009 - 06:07 PM
Last post by: ayrshiretiger
No New Posts I30 Delivery Times
7 bizzay1 598 17th October 2009 - 02:48 AM
Last post by: philipsw
21st November 2009 - 12:23 AM
Privacy Statement
