 Hyundai-Forums.com > Hyundai Models > Santa Fe Forum > 1G (2001-2006) Santa Fe
> Amp Install With Stock Monsoon
erix920
post Aug 28 2009, 10:13 AM
Post #1
Newbie
Group: Members
Status: Offline
Drives: 2003 Hyundai Santa Fe
I have a 2003 Sante Fe with the premium sound package. I'm figuring since the Monsoon has it's own amplifier that there are no preouts on the back of the head unit. So I was thinking, would it be possible to splice my rear speakers into a high low converter such as this one? I'm saying this because I already have rear speakers disconnected and have other wires running to a separate speaker box so all the wires except for ground are all exposed and easy to access.
The only other wire I have to find is the one i'm going to use for the remote turn on.
Any help would be great!
Go to the top of the page
+Reply
txsteven524
post Aug 30 2009, 05:17 PM
Post #2
Newbie
Group: Members
Status: Offline
Drives: 2004 Hyundai Santa fe 2.7-2008 Hyundai Santa Fe Se
I'm not sure on that course of action due to the fact I've never tried it. If your in the market for it this is the same one I use its about $15 more than the one on your link but its worked flawless for me. Heres The Item
Best Of Luck,
Steven B
04 Santy With about 3500 Watts in the Trunk.
+Reply
erix920
post Aug 31 2009, 05:18 PM
Post #3
Newbie
Group: Members
Status: Offline
Thanks for your reply Steven,
I was going to get that online but I was already going to Bestbuy so I just picked up a line converter.
I ended up running my remote on wire for my amp from the rear cigarette lighter to the front behind the hood release to a switch all the way back to the amp. The major problem I am facing now is if the car is or and the stereo is off, my sub starts of quiet then starts getting extremely loud (exponentially i think is the best way to describe it). The way I am fixing this is by turning down the input power to the sub. This way if you turn off the stereo is doesn't blow up the sub, only problem with this is that the sub isn't nearly as loud as it can be.
Does the happen to all subs if there's no signal or is my amp messed up? I can turn up the power to the sub without problems when the stereo is on its just when its off that causes the problem.
Thanks again!
Edit: I found the exact same problem here -> http://community.crutchfield.com/forums/p/5177/22670.aspx should I get a ground loop isolator or just try to find a better ground?
This post has been edited by erix920: Aug 31 2009, 05:47 PM
+Reply
latinmaxima
post Sep 21 2009, 08:27 PM
Post #4
Newbie
Group: Members
Status: Offline
Drives: 2003 Hyundai Santa Fe 3.5 2WD
I wish I had pictures how I did mine. I have the wiring diagram of this system cause I installed an amp under the driver seat and tapped into the wiring to the amp to get the other amp on and used an LOC from the wiring prior to the amp to get my speaker signals. It is very possible. I will try to find the wiring diagram and get it up here for you so you can wire from that. Just pull the passenger seat and all the wiring is right there for the remote and LOC to hook up to. I will see what I can do to have this up by the weekend.
+Reply
erix920
post Oct 1 2009, 04:44 PM
Post #5
Newbie
Group: Members
Status: Offline
QUOTE (latinmaxima @ Sep 21 2009, 09:27 PM) *
Thanks, are you using the stock headunit?
+Reply
latinmaxima
post Oct 1 2009, 05:26 PM
Post #6
Newbie
Group: Members
Status: Offline
I know this is the one for the non monsoon and part of it is correct but I will get you the correct one.I should have it up tonight. sorry for taking so long. I found my file and am attaching the .pdf. Good luck!!!
2003 Hyundai Santa Fe Car Radio Stereo Audio Wiring Diagram(Non monsoon)
Car Radio Constant 12v+ Wire: Red
Car Radio Switched 12v+ Wire: Brown
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Green/Orange
Car Stereo Dimmer Wire: Black/Orange
Car Stereo Antenna Trigger: Blue/Orange
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green/Black
Left Front Speaker Negative Wire (-): Light Green/Black
Right Front Speaker Positive Wire (+): Dark Green/Yellow
Right Front Speaker Negative Wire (-): Light Green/Yellow
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Dark Green/White
Left Rear Speaker Negative Wire (-): Light Green/White
Right Rear Speaker Positive Wire (+): Dark Green/Red
Right Rear Speaker Negative Wire (-): Light Green/Red
This post has been edited by latinmaxima: Oct 1 2009, 08:59 PM
Attached File(s)
+Reply
erix920
post Oct 3 2009, 02:38 PM
Post #7
Newbie
Group: Members
Status: Offline
Thank you, that is very helpful.
I needed the remote turn on wire which I now know as Blue/orange.
+Reply
latinmaxima
post Oct 6 2009, 09:21 PM
Post #8
Newbie
Group: Members
Status: Offline
Glad I could help!
+Reply
hinge817
post Oct 16 2009, 02:06 PM
Post #9
Member
Group: Members
Status: Offline
Drives: 2005 Sante Fe
just a thought on your aftermarket amp and sub going crazy on ya. sounds to me like your amp is picking up alot of electrical noise from somewhere. if i read your post right you are using the rear cigarette lighter via a switch up front to turn your amp on and off? not sure of the nuts and bolts of electric current and amps and wattage and so forth, but after installing quite a few amps and subs myself, seems to me that that might not be the best remote on/off. might be too much amperage or bad ground somewhere. also your loc might be catching interferance from where it is mounted ( power cable/wire, signal wire, etc) to close. same with your rca cables from the loc to the amp, if it is to close to a powered wire/cable, it will pick up interferance. just some thoughts for ya.
+Reply
erix920
post Oct 26 2009, 06:34 PM
Post #10
Newbie
Group: Members
Status: Offline
QUOTE (hinge817 @ Oct 16 2009, 03:06 PM) *
My signal and power cables are opposite sides of the truck. The sub doesnt buzz when I turn the input power on the amp down so you are probably right that there is interference somewhere.
+Reply
  Advanced Search
0 Members:
Collapse
> Similar Topics
No New Posts Installing Pioneer Stereo, Wiring Questions
2 sords 61 16th November 2009 - 09:08 PM
Last post by: sords
No New Posts Amplifed Vs Non-amplified
2005 Sonata and 2003 Santa Fe
0 jkamra2 23 15th November 2009 - 10:20 PM
Last post by: jkamra2
No New Posts Stock Radio Problems
2nd stock radio to go out!
4 milemaker13 94 13th November 2009 - 07:22 PM
Last post by: fonque
No New Posts Topic has attachmentsInstalling Power Options And Other Fancies.
10 MShorty 214 6th November 2009 - 07:28 PM
Last post by: JohnIrvine1
No New Posts Installing Aftermarket Stereo? Easy Question!
0 cooper1 88 2nd November 2009 - 01:52 PM
Last post by: cooper1
21st November 2009 - 02:53 PM
Privacy Statement
