i20 2009 Battery - Hyundai Forums : Hyundai Forum
 1Likes
  • 1 Post By Michael Sadler
post #1 of 6 (permalink) Old 12-23-2012, 04:02 AM Thread Starter
Drives i20
nosamr is an unknown quantity at this point
i20 2009 Battery
Could anyone help me
I need to remove my car battery to replace with a new one.
Cannot find a way to unlock it, to remove it
thank you
R. M.
nosamr is offline
post #2 of 6 (permalink) Old 12-23-2012, 06:42 AM
ADMINISTRATOR
Montego's Avatar
Quoted: 97 Post(s)
welcome to the forums
moved to the i20 forum
MONTEGO
Montego is offline
post #3 of 6 (permalink) Old 05-08-2015, 12:09 PM
Michael Sadler is an unknown quantity at this point
On a UK model 2010 petrol i20, so maybe the 2009 as well, the battery has ridges at its base front and back that locate under clips on the car. To remove the battery:
​Loosen or remove the rear clip. It is not obvious where it is. To find it, look down on the battery from above; immediately behind it you will see a shiny metal box containing electronics, on which is mounted the rear clip. Do not try to take the clip off the box. Instead, remove the box, complete with the clip;
​Start by taking the electrical connectors off the battery. There are lots of generic guides on the web on how to do this safely, so if you're not sure about this bit, check it out before you start.
Then, start the physical removal of the battery by loosening the nut on the metal retaining arm that goes out from the box of electronics to the wing (on top of the suspension strut, just by the battery earth lead connector). If it does not want to move, smother it in penetrating oil and wait, and go gently - you do not want to snap it. You'll probably only need to loosen it a bit.
Then, look behind the box of electronics, and down to the level of the battery tray, and you will see two 12 mm bolt heads. They may look quite rusty. If you then look carefully, you will see that they are holding a mounting bracket for the shiny box of electronics.
​Use a long extension and a 12 mm socket to remove these two bolts completely.
​The shiny box, complete with battery retaining clip, is now free to move and there is nothing holding the battery in.
gmth63 likes this.
Michael Sadler is offline
post #4 of 6 (permalink) Old 04-29-2016, 05:27 AM
Morris is an unknown quantity at this point
Thanks Michael - your instructions were 100% clear and it worked as well on a 2013 South African i20!!
Morris is offline
post #5 of 6 (permalink) Old 04-29-2016, 11:35 AM
MODERATOR
frupi's Avatar
i10 2nd Gen 2015 1.2 Premium - 2008 Saab 9-3 1.9 Tid 150bhp
Quoted: 78 Post(s)
frupi is an unknown quantity at this point
Morris, hi, and a very warm welcome to the i20 forum!
Please take the time to update your profile in Tools, User CP to include your country of residence and vehicle driven. This helps other forum members give more specific advice as some vehicle models do vary across international markets.
Enjoy the forums!
frupi is offline
post #6 of 6 (permalink) Old 12-10-2016, 09:59 AM
2011 i20 Petrol
pabenny is an unknown quantity at this point
Thanks - spot on for me too.
There seem to be two completely different sizes of battery fitted to an i20. Part-finders at online stores often came up with the wrong one for my car - so check measurements before ordering. Mine was an 012 size and I found the best price at Just Car Batteries.
pabenny is offline
