Timing Belt In 08 Elantra? - Hyundai Forums : Hyundai Forum
post #1 of 6 (permalink) Old 05-05-2008, 09:23 AM Thread Starter
2003 Santa Fe LX, 3.5L 2002 Jeep GC Laredo 4.0L 1993 Toyota Camry LE V6 2008 Hyundai Sonata GLS
Quoted: 7 Post(s)
noeffort
Does the 08 elantra have a belt or chain?
thanks
noeffort is offline
post #2 of 6 (permalink) Old 05-05-2008, 11:20 AM
NovaResource
The 2008 Elantra uses the 2.0L Beta engine which has a belt. It's the 2.4L Theta engine in the Sonata that uses a chain.
NovaResource is offline
post #3 of 6 (permalink) Old 05-05-2008, 12:01 PM Thread Starter
Quoted: 7 Post(s)
noeffort
Originally posted by NovaResource@May 5 2008, 10:20 AM
[b]The 2008 Elantra uses the 2.0L Beta engine which has a belt.* It's the 2.4L Theta engine in the Sonata that uses a chain.
[snapback]158851[/snapback]
thanks.
guess it would have to be replaced at 60k. Any idea what dealer charges for replacement, ballpark number.
noeffort is offline
post #4 of 6 (permalink) Old 05-05-2008, 01:47 PM
NovaResource
Well, the belt replacement is part of the 60K mile service which is about $700-800. To just replace the belt is probably about half that.
post #5 of 6 (permalink) Old 02-25-2010, 04:48 PM
fastmov4's Avatar
fastmov4
My local dealer quoted me $475 for the inspection alone. Figure about $100 for the part and the replacement would run close to $600.
NOTE: My owner's manual said replacement at 60K miles is only necessary in severe driving conditions. Otherwise, at 60K miles, it's just an inspection. I think replacement would be at 80K or 100K check-up.
NOTE-NOTE: FYI. Dealer told me that the Beta 2.0L is an interference engine. Which means (for those that aren't familiar with the term), that if the timing belt breaks, there are no safeguards in place to prevent the valves and pistons from making contact (i.e., if the timing belt breaks, engine can/will be destroyed).
2007 Elantra GLS ATX (Captiva White)
2010 Santa Fe GLS FWD (Black Forest Green)
<span style="color:blue">
</span>
fastmov4 is offline
post #6 of 6 (permalink) Old 02-28-2010, 04:48 PM
fastmov4's Avatar
fastmov4
For you technician types or someone who's already done this: can I get a DIY procedure for performing the timing belt inspection? The guy at the local quick lube place slipped up when I was asking for an estimate and told me it was just a matter of 4 bolts to get the timing belt cover off (and I assume to then perform the inspection). When I was looking under the hood this morning, it looks like he's pretty much right, except mine also seems to have a bracket or damper of some kind mounted on top of the strut tower bolt and it sits right up against the timing belt cover (oh, and I'm also assuming he didn't include the bolts for removing the engine cover). So any help/directions/pictures would be greatly appreciated!!
</span>
fastmov4 is offline
