2009 Elantra P2195, P170, P0300, P0301, P0302 etc - Hyundai Forums : Hyundai Forum
 5Likes
post #1 of 85 (permalink) Old 02-21-2017, 03:15 PM Thread Starter
Quoted: 10 Post(s)
Moose80 is an unknown quantity at this point
Thumbs down 2009 Elantra P2195, P170, P0300, P0301, P0302 etc
Hello guys, I'm trying to diagnose my wife's 2009 Elantra with the 2.0 Cali emmissions, and not having a lot of luck. Here's the story: she left to go fuel up, and then go to work Thursday morning. 1.5 miles after filling up, she was accelerating after a stop light when the car started changing engine speed (she could hear it rev, and the RPMs went to 4K), without any increased throttle input on her part. Then it started stumbling, and acting up, and couldn't accelerate. She pulled off the road and called me. I scanned it, and it had a P2195 and P0170 (O2 sensor signal stuck lean B1S1, and fuel trim B1) and I think one other very similar code. I cleared the codes, thinking it might at least get the car running normal enough to get it home but it didn't have any impact. The car could not accelerate, and could only barely move, which my initial read was limp mode.
The car starts, and idles relatively ok, but if you try to rev the engine at all it bogs down (but typically doesn't stall, but has a few times). The next day when I tried to figure it out, it was idling, and started to stumble pretty hard, whole care shaking kinda deal - it was misfiring. So it then threw additional codes for general misfire, and misfire in every single cylinder. So I go to work on checking what comes to mind. The fuel pump primes and turns off as it should, but I know that doesn't mean it it's delivering the proper fuel. I pulled the output fuel line off, and it pumped about 5oz of gas into a bottle with turning the key to the on position 3 times (priming). I had no way to check fuel pressure (doesn't have a valve to make things easy). I tested the upstream O2 sensor, and the ohms were higher than spec, but I may have done it wrong (I unplugged it and tested the wires in the harness, but maybe it needs to be plugged in?) I tested the MAF, OCV, IACV, ECU harness, fuel injecters, spark plugs and wires, ignition coils (which I may not have done properly either), and probably other stuff. I replaced the plugs and wires, they all have good spark when grounded. Everything checked out, but I cleaned up the the grounds for the battery, and ECU just to be sure. It idle's a little better, and I can now rev it to 2800 sometimes, and then it bogs down, I try again and it goes to 2650, then again, it goes to 2450...
I got a little desperate, and threw in a new O2 sensor, but as you would expect, it's not that, it's actually running lean, like it says.
I'm wondering what people think about a situation like this? Could it be bad gas? Could something be plugging a fuel line, or the filter be plugged? I wish I knew more about motors, and the vacuum system. I don't know where the vacuum lines are to look for leaks. Pointers, or a diagram would be awesome! I don't know much about Hyundai, or what these cars tend to have for issues. It just seems odd that it was running fine, then went into a seemingly Limp Mode, and has not recovered.
The live data I can get shows both O2 sensors temperature raising exactly in sync with each other - so I'm assuming that means it's not a plugged cat, but I maybe I'm reading to much into that. The AFR mixture being called for, and what it's metering are usually pretty close, but the metered reading does fluctuate, which I think is normal. Vacuum runs between -14-18 in/Hg. Evap pressure ...I'll just upload a picture of it at idle, and one of it when revved to 2800!
I hope someone can help! I did bite the bullet yet again, and I have a whole new fuel pump assembly that should be arriving tonight. But I'm worried that it won't be the problem. Take care guys, thanks for reading.
Moose80 is offline
post #2 of 85 (permalink) Old 02-21-2017, 04:06 PM Thread Starter
Quoted: 10 Post(s)
Ok, I researched vacuum leaks some, and....boy that sounds like a very likely culprit. I'll have to try to look for leaks before I install the fuel pump, so I can return the fuel pump if winds up being a vacuum leak.
Moose80 is offline
post #3 of 85 (permalink) Old 02-22-2017, 10:08 AM
2009GLS's Avatar
2009 Hyundai Elantra GLS 5spd
Quoted: 38 Post(s)
2009GLS is an unknown quantity at this point
Sounds like vacuum issues... uneven idle and problems with acceleration.
2009GLS is offline
post #4 of 85 (permalink) Old 02-22-2017, 05:27 PM
AUTOSPARK's Avatar
Hyundai Getz 1.5 CRD (D4FA)
Quoted: 953 Post(s)
Generally a vacuum leak wont make the engine bog down as you open the throttle. The wider you open the throttle the less vacuum there is in the manifold so the effects of a vacuum leak should decrease as you open the throttle, not make the engine run worse.
You said all this happened shortly after your wife refuelled the car. She didn't perhaps put E85 gas in the tank? I've no personal experience with E85 (they don't sell it here in the UK) but I'm sure I've read elsewhere on the forum that it can cause lean fuel trim trouble codes...just a thought.
AUTOSPARK is offline
post #5 of 85 (permalink) Old 02-22-2017, 06:41 PM
Quoted: 79 Post(s)
jsvob03 is an unknown quantity at this point
Definitely get the fuel checked before spending any more money.
jsvob03 is offline
post #6 of 85 (permalink) Old 02-23-2017, 08:15 AM
2009GLS's Avatar
Quoted: 38 Post(s)
Vacuum will cause the engine to bog down.
It is MAF controlled and MAF is located just above air filter. If there is extra air coming after MAF, it will mess up AFR that is strictly controlled by ECU.
Sure, vacuum decrease, but it is still there... especially when you initially depress the gas.
2009GLS is offline
post #7 of 85 (permalink) Old 02-23-2017, 03:05 PM
AUTOSPARK's Avatar
Quoted: 953 Post(s)
I've never personally experienced that type of engine behaviour caused by a vacuum leak. That's why I like this forum so much...every days a school day on here
2009GLS likes this.
post #8 of 85 (permalink) Old 02-24-2017, 08:17 AM
2009GLS's Avatar
Quoted: 38 Post(s)
You see, it all depends on the design.
In some cases, like for instance - MAP type (Manifold Absolute Pressure vs Mass Air Flow - MAF) where MAP is located near the intake manifold, any vacuum leak BEFORE the sensor will not cause any issue. However, leak after MAP will be problematic.
Same with MAF. Before - fine, after - problems.
That was not really the case with older cars - carburetors where leaks would pull more petrol within and overall engine would work fine. Of course leak AFTER carburetor would be problematic as well...
So, that's for learning.
I know for the fact Elantra HD has the MAF just over the airbox. Hence, any leak will cause all sorts of problems.
2009GLS is offline
post #9 of 85 (permalink) Old 02-24-2017, 09:15 AM
AUTOSPARK's Avatar
Quoted: 953 Post(s)
Thanks for sharing your ideas about how it all works...very interesting.
post #10 of 85 (permalink) Old 02-24-2017, 10:42 AM
2009GLS's Avatar
Quoted: 38 Post(s)
It is not my idea...
2009GLS is offline
