Fob Problem - Hyundai Forums : Hyundai Forum
post #1 of 7 (permalink) Old 10-14-2010, 08:05 PM Thread Starter
dfwtim01
Hi guys,
Question about FOB compadility?
Purchased an 04 XG350 spoke w/Hyundai dealer to make sure vehicle was equipt with keyless entry/alarm. Was quoted $169.00 for remote and $70.00 to reprogram. Thought I would try to find one online, found a few but the transmitter assy code was not the same as the one from the dealer. Asked if the different ones I found were compadible. They would not or could give me an answer because he either didn't know or wanted me to buy a new one. Does anyone know if I can get one that is compadible if so how I can tell.
Tim
dfwtim01 is offline
post #2 of 7 (permalink) Old 10-14-2010, 10:26 PM
jcmurp
Ok, First just to let you know you do not have to let the dealer program the remote. Here are instructions
and for all those who need them
I am still checking compatibility for you
1. SANTA FE / XG300 / XG350: ACCESS ALARM SYSTEM CONTROL MODULE LOCATED BEHIND DRIVERíS SIDE FASCIA PANEL
2. SONATA: ACCESS CENTRAL LOCKING SIGNAL CONTROL MODULE LOCATED BEHIND FASCIA, CENTER.
3. ENSURE MEMORY SWITCH IS IN OFF POSITION.
4. TURN IGNITON TO ON
5. WAIT 5 SECONDS, SET MEMORY SWITCH TO SET POSITION.
6. PUSH REMOTE LCOK BUTTON TO SEND CODE TO ALARM SYSTEM CONTROL MODULE
7. TO PROGRAM 2ND REMOTE: PRESS 2ND REMOTE LOCK BUTTON
8. SET MEMORY SWITCH TO OFF POSITION
9. TURN IGNITION TO OFF
10. CONFIRM PROGRAMMING BY LOCKING AND UNLOCKING CAR WITH BOTH REMOTES
11. REFIT ALL COMPONENTS IN Reverse ORDER OF REMOVAL
ONLY 2 REMOTES CAN BE PROGRAMMED AT ONCE.
jcmurp is offline
post #3 of 7 (permalink) Old 10-14-2010, 10:31 PM
jcmurp
FCC ID: PINHACOEF311T PINHAC0EF311T
dealer # 95430-3D201
CANADA: 4018104359
Beware...some of the keyless entries were not factory installed (or that is my understanding) and the dealer used a different system.
I believe this is for your car....not 100% though as several different ones were used. Also the module should have a fcc id and that should help narrow it down
The module will be located as stated in my previous post with instructions
jcmurp is offline
post #4 of 7 (permalink) Old 10-14-2010, 11:59 PM
A_Null
Well, my XG 300 didn't have a switch behind a facia panel. Nada.
Bought the car used, a salvage with no warranty, and got no remotes with it. I started researching part numbers and HMAService, and the web, but there was not much info out there that helped.
Ultimately, I got two remotes via eBay, and had to figure out how the programming was done by hand. It made for a lot of work for me, but I did document the procedure. Help yourself:
http://www.hyundai-forums.com/index.php?showtopic=17152
My doc on the web is here:
http://www.mlittle.com/Hyundai/remote/
I'd bet real money that the 350 is different.
A_Null is offline
post #5 of 7 (permalink) Old 10-18-2010, 07:02 PM Thread Starter
dfwtim01
Thanks guys,
I found one on ebay the 95430-3D201 FOR $27 SHIPPED. Hope it works.
dfwtim01 is offline
post #6 of 7 (permalink) Old 06-04-2016, 08:39 PM
pjorge is an unknown quantity at this point
Thank you! I was going crazy looking for the alarm module as per the instructions I kept finding online and the ones provided with the used remote that I got from Ebay. They where all wrong! Your simple instructions worked like a charm. By the way I have a 2004 XG350L.
pjorge is offline
post #7 of 7 (permalink) Old 12-14-2016, 11:13 PM
csjdennis is an unknown quantity at this point
Can't make 2 Key FOBs work
Are you still available for inquiry?
I lost and replaced a Key FOB. Using your procedure my 2004 XG350 will accept and operate with either the replacement OR the second unit that came with the vehicle but NOT with both.
Do you have any thoughts or ideas?
Are details available for the generation of your procedure?
Thanks.
csjdennis is offline
