Turn Signal Flasher - Hyundai Forums : Hyundai Forum
post #1 of 12 (permalink) Old 10-19-2005, 01:59 PM Thread Starter
recontango
has anyone had a problem with tiburon turn signals? My right turn signal stays on constantly, and when I flip the switch, I hear a fast clicking as is a bulb is out, but one isnt. I called the dealership and they said there isnt a "flasher" avaliable for the tiburon. Anyone have any ideas??
recontango is offline
post #2 of 12 (permalink) Old 10-19-2005, 02:11 PM
ADMINISTRATOR
Montego's Avatar
Quoted: 102 Post(s)
welcome to the forum
are all the three flasher lights on the right side flashing brightly?
MONTEGO
Montego is offline
post #3 of 12 (permalink) Old 10-19-2005, 02:31 PM Thread Starter
recontango
They dont flash, are on bright all the time.
post #4 of 12 (permalink) Old 10-19-2005, 02:34 PM
ADMINISTRATOR
Montego's Avatar
Quoted: 102 Post(s)
o/k so if the flashers are working normally on the left side there must be a wiring fault on the right hand, your car should still be under waranty, take it to your dealer
MONTEGO
Montego is offline
post #5 of 12 (permalink) Old 10-26-2005, 03:20 PM
midlifecrisis
I had the exact same problem not long after buying my car a couple of years ago. They diagnosed it over the 'phone and told me it was the 'body module' at fault. Took it in to them, they changed aforementioned module and all has been fantabulous ever since.
Hope this helps
Dave
ps They have to re-code your keys after changing this so make sure you take both/all sets in with you!
midlifecrisis is offline
post #6 of 12 (permalink) Old 10-27-2005, 03:14 AM
Loco_one's Avatar
Loco_one
Send a message via MSN to Loco_one
Had the same problem as you when i bought my 03 tibby the dealership had to change the flasher relay or as they called it the flasher computer to fix the problem. my only problem is when they did that my remote door locks stoped working and now have to be re-programed.
Loco One
Tibby 4 Life
Loco_one is offline
post #7 of 12 (permalink) Old 10-28-2005, 08:52 AM
johnc
Post
Omron electronics are reknowed for faulty body control modules, Hyundai oz tell me that there is no removable flasher because it is integrated in the body control circuit board. Peugeot use a microprocessor to run the indicators hyundai still use an old fashioned relay with bulb breakage detection. Your problem is usually cause by the indicator relay circuit remaing open causing reverse polarity and thus giving you grief. Aim high get a new unit and check the system prior to completion.
Good Luck,
johnc is offline
post #8 of 12 (permalink) Old 02-23-2008, 02:34 AM
chusteveb
Is this a known issue? I have a 2004 Tiburon that has the left side on bright all the time, even when the car is turned off! I didn't find a flasher on the fuse panel so now I'm here searching for some answers. Any insight would be greatly appreciated!
chusteveb is offline
post #9 of 12 (permalink) Old 04-12-2008, 02:53 PM
Vic
Vic's Avatar
Vic
It is the BCM that's at fault. This can cost around $600 if not under guarantee. BUT you can fix it for about $5
Take a look at http://www.newtiburon.com/forums/showthrea...1&highlight=bcm
I did this DIY in August 2007 and it is still working just fine
VBR
Vic
Vic is offline
post #10 of 12 (permalink) Old 02-07-2010, 08:49 PM
Natasha_m
QUOTE (Vic @ Apr 12 2008, 01:53 PM)
Take a look at http://www.newtiburon.com/forums/showthrea...p;highlight=bcm
VBR
Vic
Thanx for your tips!!! So much!!!
Can you just tell me, where can I buy this <relay> and which one is for the left and for the right one?( if its not written on it)
Natasha_m is offline
