I have a very strange problem with my car and I am trying to find a solution. It is something to do with wiring/fuses in my car. It used to drain energy and my clock lights were always on. I changed the battery myself, not sure what or when I did, but my car started loosing electrical supply entirely when the keys are out and clock light was no longer on, radio lost its setting every time, hazard lights and central lock did not work. Today they fixed it at a garage, but it is now back to energy draining situation clock lights are always on. Now central lock works with key, but not the wireless fob. It never worked with wireless fob. I have read the resetting instruction. Here are my findings, in the situation when the car lost all power without key, I put the key in, turn to acc mode, press unlock button on the fob as per instructions in the manual the indication would blink as per manual, but as soon as it is set and I take the key out, the car looses power and the central lock does not work. In the situation where the power is now back on and the clock is always lit up with blue background light, when I put the key in and turn into acc mode, press the unlock button on the fob, nothing happens, no indicators blink, wireless fob does not work. I think the car does not understand that it is in off mode (because some circuits are still powered). Probably does not make any sense to you, sorry for that, but please help if you can, guys at the garage could not fix it.
Two things I am trying to achieve - to make sure the battery is not draining energy, my wireless fob works.
