lol so I guess these cars are pretty popular than. I've somehow only discovered them a couple weeks ago when this purchase was made. After all the minor and maintenance work done to it Ive reached the dreadful bcm. Since you guys told me about how common they go bad alot of research on google only backed that up. So I'm just preparing for the worse and browsing ebay for them. I hope it doesn't come down to it but if it does is there any programming involved in this or is it just plug in and go?
Car doesnt have any alarm system that Im aware of and no keyless remote or anything like that. Oh Im still kinda unclear on how to approach the bcm with the multimeter. Am I putting both positive and negative meter leads on the bcm pins or the wires in the connectors ?
You don't want to use your meter for what Sparks suggested. He was suggesting you run 12V to the pins in the connector to see if the bulbs lit. Your meter can't handle the current (about 3.5 amps or so) on the Fused sied, and don't want to do it unfused. I use a straight piece of wire, but I've been a tech for um...well...er, a LONG time, so I take my chances with educated guesses. Not wise for a beginner!
That's why I put up the pic of the fuseholder. You can get them at almost any hardware store, AutoZone, O'Reilly's, etc. You cut the loop and then strip the ends, so you have a wire with a fuse in it. If it only lights up 1 bulb at a time then we're talking about 2 amps or less.
Wait till Sparks weighs in, but I believe you want to run 12V to the pins on the connectors he referred to. This will light up the bulbs in the front and rear...won't flash, just turns them on. Then we know the wiring is OK. So then we try to determine if it's the switch or the BCM. I believe this is what he was trying to do.
Now..since I don't know this car's wiring at all, what I would want to try to do is send a "signal" to the BCM to turn the flasher on. I believe this means
grounding one pin with the key on and the plugs inserted into the BCM/Fuse box. Sparks would have to run that down for you. Then we could tell for sure if it's the BCM or the switch.
BTW,
Car-Part.com--Used Auto Parts Market will find parts in your area, or further since the BCM can be mailed fairly easily.
