Getz Antenna - Hyundai Forums : Hyundai Forum
post #1 of 8 (permalink) Old 05-29-2007, 03:10 AM Thread Starter
tubbydrawers
my wife has broken the antenna/aerial on the top of her getz.
hyundai want to charge us $80 for the part and $200 for labour.
Is there anyway of doing it myself? it is snapped off right at the end of the stump, do i need to get at it from inside the car or can it be removed from the top.
how does the new one fit in as i have not seen one yet so i dont know exactly how it is fitted.
thanks
tubbydrawers is offline
post #2 of 8 (permalink) Old 05-29-2007, 07:29 PM
B2Bomber
i'm a little bit slow on imagination... do you think you could provide a pic?
B2Bomber is offline
post #3 of 8 (permalink) Old 07-20-2008, 04:40 AM
Richardx
I've got the same problem. They told me that the labour cost was because they need to take the inside roof lining out to replace the aerial. Has anyone tried taking the lining out?
Richardx is offline
post #4 of 8 (permalink) Old 07-22-2008, 07:19 PM
pialbert
same here, actually mines worse, when someone tried to nick my antenna the whole thing came off! even the base. now i have two holes in my roof
anybody here please need some advice!!!
pialbert is offline
post #5 of 8 (permalink) Old 07-26-2008, 02:40 AM
Medic_01's Avatar
Medic_01
this is the standard getz antenna.
i reckon one of those shark fin anteannas like on BMW's and stuff would look nice. i can't imagine it would be hard to mount to the roof.
but removing the interior trim and stuff, i have no idea how to.
Hyper Auto Club - Australia's Best Hyundai Club
Medic_01 is offline
post #6 of 8 (permalink) Old 07-27-2008, 01:05 AM
Richardx
I've worked out how to replace the antenna. Remove the sunshades (2 screws each). Remove the handle from over the passenger side door (2 nuts) and the sunglass holder (what a joke) from over the drivers door (2 screws). Pull back the plastic strips that go down each side between the windscreen and the doors (held on by plastic clips).
Get someone to hold the roof lining down and you can remove one nut that holds the antenna from the inside. The wire from the antenna to the radio is also held in place by this nut.
There is a wire under the lining near the drivers door that goes to the interior light - make sure you don't break it - I just removed the piece of tape that was holding it onto the roof lining.
Now I just need to buy a new antenna.
Richardx is offline
post #7 of 8 (permalink) Old 08-07-2008, 06:56 AM
sc00ter
Hey guys, this might be a bit late for some of you but a little advice in replacing the antenna.
If the getz is the same as in South Africa then it is a 3 piece unit, a bee sting aerial (the part that screw loose on top), the base (part that fastens to the roof) and the cable. Yes the cable is loose from the base.
To remove: Remove the interior courtesy light lense (use a small flat screwdriver)
Once removed you will see 2/3 screw holding the plastic casing into the roof lining, remove them and remove the casing. Unplug the electrics for the globes.
Once that is out of the way you will see the antenna base securing bolt. It is alittle hard to get to but use the smallest socket set you have with a universal swivel and a No 10 socket (metric) to loosen.
You will now be able to remove the base and note the aerial cable is held on by the same nut that loosens the base.
Once off you can replace the base only or you can go further into the DIY like I did.
I found that the cost of a new antenna from the agents was ridiculous so I did what we do in SA with a saying "Boer maak n plan" which translated means "a farmer makes a plan"
I had a look at the bits I now had stripped and found that the base has the "bolt" that the aerial screws onto not the other way round.
Let me explain a bit. Some antennas have the "bolt" on the removable aerial and the "nut" is on the base. If you look at yours you will see what Im saying.
Now, if it has snapped off like mine then the "bolt" bit will be in the removable aerial piece. Mine was discarded without my knowledge and so I was left with only a base. I then bought a cheap unit from the local electrics store, one that had the "bolt" piece on the end of the removable aerial. I checked the size of the "bolt" and then drilled a 4mm hole in the centre of the base section where the aerial fits, then took a M5 tap and tapped the hole.
Check the new removable aerial fits and use a thread glue if needed to make sure no one steals it. Replacing everything is the reversal of removal.
Alternatively, if you have the bee sting still with the "bolt" piece still inside it, you can remove that piece using "easyouts" (may differ in countries), without damaging the thread on the aerial. Then continue as above with tapping a new thread on the base. Then buy a bolt that fits the bee sting and newly tapped base. Cut off the bolt head and use the threaded shank as your new "bolt"
Hope this helps. Unfortunately I dont have photos but if there are any questions, please ask away.
sc00ter is offline
post #8 of 8 (permalink) Old 02-01-2009, 01:28 PM
yuusha
I have a problem with my aerial. I cannot unscrew the thing. Any ideas? I think it might be glued in or are they just really hard to unscrew?
yuusha is offline
