Hello, I've got a 2006 Hyundai Getz GSI and unfortunately my screen washer isn't working. I presume a fuse has blown. Where is the fuse? Thanks in advance for your advise, Alan
Fuse box is under the dash. on the right side.............if you can't hear the pump working its more likely to be a worn out pump (not uncommon) also check wiring connections on the pump housing
Thanks Montego. No I can't hear any noise. Would a novice be able to change the pump OR would I be better to take the car to a garage? Thanks again, Alan
the pump and fluid reservoir are fitted on the front right of the car, you will need to jack the car and remove the right front wheel, then release the screws/plastic clips that hold the front part of the plastic inner wing shield, pull the plastic away from the front and you will see the pump. the pump just pulls out of the plastic reservoir bottle, pull off the wiring connector and the water pipe and fit the new pump, re-fit the inner wing shield, sounds complicated but its not
410K members
