Hi
Was wondering if any one could help. So hear goes
The car from factory only had powers locks operated from the drivers door only.
I installed an after market remote Central Central locking kit that uses and actuator in the drivers door to operate the doors lock which in turn operates the other door locks.
All was working well for over a year until it stopped operating any door.
Upon inspection I found the after market kits actuator had broken.
So I replace the actuator.
Now only the drivers door would lock, but I'f the engine was running all the doors would work.
So I thought it was a power problem.
I got the car batter tested and it was faulty , so I got it changed.
However only the drivers door will lock still. Unless the engine is running.
Everything still works as normal with the key in the drivers door or if you just press the door lock I when in the car.
Hope this makes sense and you can help
Thank you
Doug
Thank you
Doug
