right im loosing the will to live i have a getz 1.6 sport 2003 model it was my mums car she had from new any way i have it now and when she had it the last couple of years at just under 2000rpm there is a rattle? vibration? some sort of noise but goes after 2000rpm its driving me insane its from the left side now it does not do it in neutral so i cant check where it is coming from so next step i jacked the front up and guess wat it did not make the noise so it only does it when its on the road and driving first thing i did was check the heat shield for a crack but nothing please some one help and save this getz from a lump hammer cheers
I'd get a rubber mallet and tap/check EVERY part of the exhaust system, don't be too gentle with it as you need to make sure it has enough clearance from other parts etc etc, could even be the cat itself, broken inside will give you that rattle... good luck
hi thanks i will try that over the weekend im thinking its not the cat as it is coming from the left side front i will post once i have been under it again and checked the entire exhaust system thanks for the advice
right checked the entire exhaust system and all is ok so back to square one wat i dont understand is how can the noise be there when on the road and in motion but once its jacked up the noise goes???
