Getz 2005 Manual Fuel Gauge malfunction
2K views 1 reply 2 participants last post by  iana
The Fuel gauge in the instrument cluster of my Getz 2005 Manual malfunctions as follows
. Some time ago the low fuel indicator globe ceased to light up but the gauge otherwise worked properly.
.Recently the gauge needle will not return to the empty position when the engine is turned off. I have disconnected the battery (both terminals) and this makes no difference.
. Ther gauge went up when the tank was filled and seems to be gradually coming down as the fuel is used but the gauge still does not return to Empty (or 0) when the engine is turned off.
Any clues?
#2 ·
Any clues?
that's how it works... it's normal operation for this car.
