I know this topic comes up alot but I just got myself a used '06 Getz. Little did I know after the purchase the carpets were wet and had a slight smell to it.. it's water not coolant.
I have read over and over about the air conditioner evaporator which has to dump the condensed water outside the car, through a drain pipe that goes through the firewall.
Apparently this gets clogged up and causes the water to leak through into the cabin?
So... where is the overflow tray/pipe/drain located to un-clog it? I see the small one in the engine bay itself but is that the only place? Getting tired of looking around the car for the problem, pretty sure this is it though.
Any help before I sent it to a mechanic would be great haha.
