I´m new to this forum, as well as i´m new to driving Hyundai But quite satisfied so far..
However, my clutch are worn and i need to replace it. I have searched the net quite some time to find a workshop manual or an instruction on how to change the clutch, but i can´t find anything
Can any of you help me with a workshop manual, or just a scan of the clutch replacement part??
The car is a Getz 1.5 crdi 82 hp 3 cyl. from 2004.
I have already tried youtube - nothing there.
I am capable of using a manual. I have made alot of volvo's so far, but would for this job like a manual for support - what to remove and in what order etc.
I think a manual is very good to have in hand when doing bigger operations like this
wait at night , i had the info. Some years ago I changed my Clutch to, basically need remove driver tire, and some stuff near, it took me about 4 hours. So you must to have a good place and good tools,if not is better get to local workshop.
Remember you must to rectificate balance wheel
If you do it would be useful to write what points had difficulty,
example to remove manual transaxle from flywheel or to remove the controller arm from the top of the trans.
Plokami : Exactly what i needed!! Many thanks! At some point it says "remove the transaxle assembly (refer to the TR group). Do you have that part as well? That would be perfect.
It will be some weeks before i begin the replacement, but i will post some info when i'm done.
Again thanks
