I'm in Australia and have a 2007 Getz 5 door hatchback.
At most engine revs, an annoying buzz/rattle can be heard from somewhere under the dashboard. The noise is there when the car is stationary or moving.
I have tried pressing down hard on the top of the dash but the noise doesn't stop. Is there an easy way to get deep under the dash? I am suspicious a foam or rubber pad or spacer may be worn, I had a similar rattle in the driver's door panel once. I replaced all of the hard foam blocks and it was fixed.
Thanks,
Dave
Thanks,
Dave
