In the begining I thought it was the lamp. After changing I saw that it was not the problem.
I measured both lamp poles and I had 12V in both!!!!!!As far as I know this shouldn't happen.
The rear boot open warning light in the cockpit also doesn't light on when boot is open.
I check for sensor and dind't find it, i thought it was in the tail gate and discovered there a wire, is the sensor there?
I checked this wire, measured it and read 12V. I disconnected the wire and nothing hapened. Both light (boot light and boot open warning) kept off.
Can anybody help please?
Thank you
Thank you
