I have a Hyundai Getz 2004 model and my rear window heater and rear window brake light have stopped working. I am thinking it might be a fuse but don't know where the fuse box is on this model and when I locate it how do I know what fuse is for what ^_^
The fuse box is under the dash. However if both the brake light and rear demist are not working it would suggest a break in the wiring going to the tailgate, check the cables under the rubber casing where the tailgate hinges for any break also check that the tailgate frame in grounded..........if you have trouble with this you may need an electrician
Thanks for that advice will try the fuse first and if that fails will take car to my local garage
410K members
