Hi,
Can you help me please. The Air Conditioning is not working on a 07 Getz 1.5 cdx+ CRTD UK right hand drive. I have checked the fuse inside the car and in the engine bay. The relay in the engine bay and the on/off switch in the car. The pump is not being turned on (the relay is not being activated). If I bypass the relay and join the connections direcly the pump turns on. Does anybody have a wiring diagram they can send me please? Is there a control box somewhere? apart from the fuses, switch, pump and relay what other things should I check? I can see a sensor or something on one of the pipes but I have no idea what it does. Thanks Vince
