Tappet Noise - Hyundai Forums : Hyundai Forum
 1Likes
post #1 of 11 (permalink) Old 06-27-2011, 12:43 PM Thread Starter
shafiekd
Hi
I have a Getz 2004 model with 162000km on the clock.
Until 2 months ago i had tappet noise only at startup and it normally goes away when its hot.
Now its noisy when doing anything above 2000rpm, obviously a bit quieter than when cold.
Does this model have hydraulic tappets? if not, can it be set manually & what is the clearance settings?
shafiekd is offline
post #2 of 11 (permalink) Old 06-27-2011, 06:35 PM
MODERATOR
RBURGOSS's Avatar
Quoted: 6 Post(s)
QUOTE (shafiekd @ Jun 27 2011, 11:43 AM)
Hi
You do not specify which engine is in your Getz. Anyway, all of them have hydraulic tappets (lifters) so there is no adjustment here. If you consider the tapped noise is abnormally high, I suggest having your engine looked by a qualified mechanic.
162 thou kms is not that much, but it may be a sign of oil contamination due to carbon buildup, making oil pressure under tappets lower than what is needed.
Have you replaced the timing belt? By now, you should have done it at 80 thousand kms and about ready for the second timing belt replacement.
Robert B.
Don't forget to participate and vote in the February 2013 ROTM thread at
RBURGOSS is offline
post #3 of 11 (permalink) Old 06-27-2011, 09:46 PM
jsinton's Avatar
Quoted: 69 Post(s)
Do you change your oil often? These little hydraulic tappets get real noisy when the oil is low or tired.
jsinton is offline
post #4 of 11 (permalink) Old 06-28-2011, 10:16 AM
MODERATOR
RBURGOSS's Avatar
Quoted: 6 Post(s)
QUOTE (jsinton @ Jun 27 2011, 07:46 PM)
Just to add a bit more gasoline to this fire... According to my mechanic, hydraulic tapped noise when everything else is OK (no signs of carbon buildup in valves, no measurable wear on the camshafts, no timing belt streching out, no oil galleries and in-block ducts clogged) it can mean one of two things:
Low cost situation: Your engine is running low on oil. More than a quart is missing.
Expensive situation: Your oil pump is failing.
Robert B.
RBURGOSS is offline
post #5 of 11 (permalink) Old 06-28-2011, 02:06 PM
MODERATOR
RBURGOSS's Avatar
Quoted: 6 Post(s)
UPDATE ON HYDRAULIC TAPPETS.
Just checked with Hyundai service manuals. The 1.1 SOHC liter engine does not have hydraulic tappets (lifters) which mean that the valve clearance must be adjusted from time to time.
Valve clearance Warm: 0.2 mm intake, 0.25 mm exhaust.
Valve cleanrance Cold: 0.1 mm intake, 0.17 mm exhaust.
All the DOHC engines (including diesel) all have hydraulic tappets.
The 1.3 liter SOHC is not equipped with hydraulic tappets, but it has HLA (Hydraulic Lash Adjusters) that may become worn out and may need replacement. This devices are part of the rocker arms that push the valves.
UPDATE ON POSSIBLE CAUSES FOR TAPPET/VALVE NOISE AFTER 15 MM in WARM ENGINE:
1) Too low or Too high oil level.
2) Oil degraded or contaminated.
3) Too low oil pressure (cause by 1 or 2, or oil pump failure)
4) Faulty HLA (1.3 liter SOHC engine only)
Karaoke Kop likes this.
Robert B.
RBURGOSS is offline
post #6 of 11 (permalink) Old 01-27-2015, 05:51 AM
Getz 1.1
eric palis is an unknown quantity at this point
thank
you so much my Getz is due for servicing no idea before...
eric palis is offline
post #7 of 11 (permalink) Old 01-27-2015, 06:50 PM
wife's 05 Getz, E46
Quoted: 5 Post(s)
iana is an unknown quantity at this point
also make sure you get a GENUINE Hyundai oil filter... it will help for sure!
iana is offline
post #8 of 11 (permalink) Old 02-03-2015, 11:41 AM
ozyguy is an unknown quantity at this point
what viscosity (thickness) of oil do you use?
if it is too thick eg 30/60 your oil pump may not be able to pump enough oil, you should still be using about 10/30 or 10/40 oil if you live in a warm climate or check with your mechanic if you live in a colder climate you will need to use "thinner"
if your engine is getting a bit "worn" you may need slightly thinker oil
ozyguy is offline
post #9 of 11 (permalink) Old 02-04-2015, 05:02 AM
wife's 05 Getz, E46
Quoted: 5 Post(s)
30/60 ???.... that's not oil, it's treacle!
the car is a Getz, not a bulldozer.
iana is offline
post #10 of 11 (permalink) Old 02-18-2015, 01:45 AM
Al Glenn's Avatar
Drives Getz 1.1G Model 2007
Quoted: 2 Post(s)
Al Glenn is an unknown quantity at this point
Hi Iana, I am using a Ginza brand on my Hyundai Getz 1.1 Gas 2007 model but I see no problem or issues at all though using original Hyundai filter(more expensive) is excellent but I believed that the use of quality engine oil and regular oil change interval the biggest factor in maintaining good engine.
Al Glenn is offline
