Hi, I have an 08 Getz that has been having intermittent faults with the immobilizer. When the ignition key is turned to the on position the immobilizer warning light will flash once and the engine is ready to start. However very often the warning light will flash 5 times and then the engine will crank but not start.
The owners manual says that if the immobilizer warning light flashes 5 times it has a fault and needs to be taken back to the dealer. The first time returned to the dealer they couldn't find anything wrong( at that stage it had not been discovered it was an immobilizer fault), the second time they reset " the immobilizer" and it was fine up until 3 months ago.
Again we are having the same problem and it's getting progressively worse with many attempts to start. It has been back to the dealer and they reprogrammed the keys and replaced 1 key. On picking it up from the dealer the same no start fault occurred in their car park so we are back to square one.
Has anyone here had any experience with this problem?
