Interior Lights - Hyundai Forums : Hyundai Forum
post #1 of 12 (permalink) Old 03-27-2010, 08:26 AM Thread Starter
wendy151
Hi there just wondered if anyone has any ideas,
My Hyundai Getz interior light has stopped working, I have changed the bulb, (new one) did nothing - still not working
Checked the fuse in the yellow cage - ok,
Even took down the interior light to check the wires are ok. Yep fine!
any ideas?
My boot light works when I open my boot, my clock works, door open light, etc as well as everything else.
Any help would be really grateful as now i am fed up of trying!!
Please help
Wendy
wendy151 is offline
post #2 of 12 (permalink) Old 05-09-2010, 01:15 AM
snh280
Hi Wendy 151. I too have the same problem. I've done exactly the same as you and still no joy. It's very frustrating and even more so when no one replies!! Have you managed to fix it yet, and if so, what did you do?
Simon.
snh280 is offline
post #3 of 12 (permalink) Old 05-14-2010, 04:14 AM
snh280
116 views and no replies????????
snh280 is offline
post #4 of 12 (permalink) Old 05-15-2010, 04:52 AM
engineern6719
I will try and help. Your interior light is fed a positive via a fuse directly to one side of the lamp. A negative or ground is fed to the other side of the lamp to operate it from two paths depending where you have the selector switch next to the interior light selected.(continually on or through a door open)
My suggestion would be to drop the interior light assembly down and take some voltage readings .If positive 12 volts is present check for a missing ground through the selector switch or a faulty selector switch. Hope this helps.As you can see I own a 2004 model Getz so I can only speak with regard to this model. I don't know wether things have changed in the later models.
I thought if the vehicle was only a couple of years old that this repair would be covered under warranty. However I just had a look through a later model workshop manual for the getz and the grounds for the interior light go through a box called a"Electronic time and alarm control module"or ETACM for short. The earlier series vehicle like mine doesn't have that. If there's no ground at the light assembly maybe there is a problem with this box.
engineern6719 is offline
post #5 of 12 (permalink) Old 05-28-2010, 03:05 AM
snh280
Thanks Mate.
snh280 is offline
post #6 of 12 (permalink) Old 05-31-2010, 03:49 PM
divalljohn
QUOTE (wendy151 @ Mar 27 2010, 08:26 AM)
any ideas?
Please help
Wendy
I have trajet and only boot light working, have rewired middle ceiling lights to come on but door onescannot. You will have to just rewire. design fault
divalljohn is offline
post #7 of 12 (permalink) Old 06-20-2010, 02:02 AM
scott_eboy
Post
QUOTE (engineern6719 @ May 15 2010, 06:52 PM)
Hi - you mentioned that you had a look through a later model workshop manual for the getz - I am in the process of purchasing a 2010 Getz and would be keen to get hold of a copy of the workshop manual - any chance of letting me know how to get hold of a copy of the workshop manual??
Any assistance with this would be appreciated.
scott_eboy is offline
post #8 of 12 (permalink) Old 06-20-2010, 11:52 PM
junetix
QUOTE (wendy151 @ Mar 27 2010, 05:26 AM)
any ideas?
Please help
Wendy
do you think u can help me out with the light bulb sizes of the interior lights? possibly the license plate light too? if you could let me know that'd be AWESOME!
junetix is offline
post #9 of 12 (permalink) Old 06-23-2010, 03:53 PM
engineern6719
QUOTE (HipHopRed @ Jun 20 2010, 04:02 PM)
I have a 2004 model Getz . I purchased a manual through Hyundai and cost me $190.00 . It was supposed to cover the model I had but was for a later model in that series. I ended up downloading a copy of the manual from this forum which covered more than the $190.00 one. It was the circuit diagrams I was after so I could add keyless entry to the car.
So I suppose you could try and do a search on the web or pay through the nose and try and buy one Hyundai.
post #10 of 12 (permalink) Old 07-24-2011, 06:16 AM
vmdaemon
any ideas?
Please help
Wendy
Hi guys,
I've had this same issue so I thought that I'd post my fix.
If you remove the interior light assembly, and uncable it. You should notice the 'tracks' or circuits of the unit. One of my tracks had completely oxidised (gone green). I had to clean the track and connector on the switch to remove the oxidisation. Then it worked better.
It truly is a 5 minute fix.
Hope this helps.
Sean
vmdaemon is offline
