Hyundai Forums : Hyundai Forum (http://www.hyundai-forums.com/forum.php)
-   GD (2013+)Elantra GT (http://www.hyundai-forums.com/gd-2013-elantra-gt/)
-   -   2014 Changes (http://www.hyundai-forums.com/gd-2013-elantra-gt/179906-2014-changes.html)
ElantraGeeTee 08-29-2013 09:33 AM
2014 Changes
Cross posted from the 2014 Elantra thread on the 2011 sedan board, Thanks to user GingerC
http://imageshack.us/a/img585/5382/tkvs.jpg
Notable additions
LED tails and the 2.0 GDI engine.
Now , wheres that Turbo option at Hyundai?
CubSmurf 08-29-2013 11:44 AM
Notable additions
Interesting, looks like they dropped the 'Touch and Go' package. That was the best one of the 3, glad I got mine when I did. Curious about the 2.0 GDI engine...what's the specs on it?
EDIT: AND they are adding the LED taillights?????? JERKS:) Should make it easier to add to the 13's though as they should start being in stock...
ElantraGeeTee 08-29-2013 11:51 AM
If Im correct here , the new GDI 2.0 going into the the Elantra line is the very same from the 2014 Kia Fortes , which would put the output at 173 hp with 154 pound-feet of torque
CubSmurf 08-29-2013 12:03 PM
I'm curious to see how it does in the GT. Reading the info I can find, looks like it'll have marginally more power but also worse MPG. Doesn't seem like much of an upgrade, not sure why they are making the switch.
ElantraGeeTee 08-29-2013 12:04 PM
the 2.0 is rated at 24/36 vs our 1.8 at 26/37
Not that much of difference to be fair.
cbzdel 08-29-2013 12:16 PM
T & G was the best package as I didnt want leather, sunroof or navigation, but didnt want a total base model.
CubSmurf 08-29-2013 12:36 PM
True, but if the numbers are optimistic like ours are then in mixed driving the 2.0 will average high 20's. That would not be good. Like I said, curious to see how the numbers play out...
And cbzdel, the Touch and Go was the best pkg for me too. I also didn't want the sunroof, but wanted the upgraded wheels. Doesn't hurt that I basically got Touch and Go for free because the dealer listed the price wrong online. Car was listed $900 cheaper than it should have been, but the dealer honored the pricing. :)
Xion 08-29-2013 02:45 PM
It's sad that if you want the panoramic sunroof you must take the NAV system, I prefer aftermarket NAV system.
MEC-777 08-29-2013 03:29 PM
The 2.0L is 156hp and 144ft-lbs.
The 2.4L is an option for the Forte (or used to be) at 173hp and 154ft-lbs.
Regardless, it's a nice little bump from the 1.8L's 148hp and 131ft-lbs. Not much of a power difference, but what you will feel most is the extra torque.
ElantraGeeTee 08-29-2013 03:49 PM
and I quote
"The Forte offers a choice of two new four-cylinder engines, one for each of its two trim levels. The base LX is towed by a 1.8-liter rated for 148 horsepower and 131 lb-ft of torque, this one borrowed from the Hyundai Elantra parts bin. Moving uptown to the Forte EX nets a 2.0-liter with 173 horsepower and 154 lb-ft. Both have dual overhead cams, 16 valves, and variable valve timing, and both share an 81-mm cylinder bore. The 2.0 has a longer stroke (97 mm), a higher compression ratio (11.5:1 versus 10.3), and direct injection. A six-speed manual transmission is available, but only with the 1.8-liter engine. A six-speed automatic is optional there and standard in the EX."
Thats courtesy of the Car and Driver 2014 Forte First drive, and I dont really think its a leap to expect that very same GDI 2.0 in the 2014 Elantra line . :cool:
Powered by vBulletin® Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
